Engine Fan
Old Jan 9, 2004 | 02:39 PM
SingRX8's Avatar
Engine Fan
Hi guys, encountered something funny(at least to me) today. After some hard driving, i realised that the engine fan continued to run even after i switched off the engine. Stood outside for a gd min or so but the fan juz kept on running. It stopped only when i inserted the key again and turn to start but w/o starting the car.
Does any of you fellows 8ers experience this problem? Or mayb it's not a problem at all? Thks!!
Old Jan 9, 2004 | 02:43 PM
93rdcurrent's Avatar
The Stickinator
Most cars today have an automatic cooling fan on the radiator that will kick on even if the car is turned off when the coolant requires cooling. Sometimes it will take a minute or two after the car is shut down to kick on but it isn't a problem. It's a good thing as long as it is relatively warm when it is happening. If it does it when it -30f outside then you might be concerned.
Old Jan 9, 2004 | 02:49 PM
Omicron's Avatar
Yup, it's normal.
Old Jan 9, 2004 | 02:50 PM
eccles's Avatar
Prodigal Wankler
It's normal, it's thermostatic, and it's been discussed before. The search engine is your friend.
Old Jan 14, 2004 | 08:33 PM
Sin's Avatar
Sin
Just had this problem today for the 1st time...mods are listed in sig and I thought it might have had something to do with the REintake. Only because I recently had the black nipple on the car plugged when it should have been exposed so the car was dying at idle at high speeds...Is everyone sure that nothing is wrong? ..Thanx
Nevermind, I read even more threads..later
vapor2
Nov 3, 2020 03:38 PM
rotorocks
47
May 11, 2016 03:23 PM
Nisaja
Aug 6, 2015 01:27 AM
Ryosuke-
12
Jul 24, 2015 12:51 PM
Majictoast
Jul 16, 2015 05:55 PM
