So I removed my K&N Typhoon II
Old Sep 20, 2009 | 08:26 PM
rotarykillz's Avatar
Rotary Freak
I had heard they can actually hurt your power. I wanted to see what kind of air induction force I was getting without it. I was checking on my CarPC and during heavy acceleration I was getting between 12-15 lbs of pressure measured by the MAF. After putting the stock back on, I peaked at around 20lbs of pressure.
Not only is the air hotter, but the pressure was better with the stock....really total BS imo. I'll do the community a favor and NOT resell this POS K&N.
I definitely felt better pull with my car afterwards too, so it was more of a downgrade. Guess I need to look at a CAI instead of short ram.
Any comments, suggestions? My next mod WILL be a high flow CAT, but I won't do a CAT delete. I want to keep it legal.
Old Sep 20, 2009 | 08:28 PM
dondo's Avatar
100% baller (finally!)
aem/mazdaspeed cai ftw
Old Sep 20, 2009 | 08:29 PM
Yeah most intakes are just for sound. Really no usable HP. I've seen stock cars dyno with the same HP as 8' with Intakes of different brands.
Old Sep 20, 2009 | 08:33 PM
9k: not necessarily.
some intakes can definitely help deliver more (colder) air which CAN help the engine and produce added performance.
I would suggest:
Racing Beat + Duct
AEM / Mazdaspeed
Old Sep 20, 2009 | 08:39 PM
jessedrifter's Avatar
so cal
so u dont want to sell it ; ) haa
Old Sep 20, 2009 | 08:56 PM
Symbioticgenius's Avatar
You Dumbass!!!
I would just put the RB duct on the stock intake and call it a day.
Old Sep 20, 2009 | 08:57 PM
TX
I would suggest:
Racing Beat + Duct
AEM / Mazdaspeed
Well its such and insignificant gain that it does not relate to faster times on a track.
Old Sep 20, 2009 | 08:58 PM
on K&N Version 2, the MAF location is wrong, I think they did it on purpose tho. that way it can trick the ECU into thinking its getting less air, less air = less fuel. but the truth is its getting more air than stock (it does), so the mixture will be lean.
this trick only works in open-looped tho, when its closed-loop mode. its useless.
Old Sep 20, 2009 | 09:00 PM
so cal
or doo u? lol
Old Sep 20, 2009 | 09:05 PM
its about 0.05 seconds faster.
mdl0209
May 23, 2019 05:46 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
