Turbo- what kind of Cruise AFR are you running?
Old Sep 13, 2009 | 06:21 PM
Mawnee's Avatar
I divide by zero
I've started tweaking my Closed Loop fuel to get my fuel mileage back and smooth out a little bucking in low rpm. Just wondering how lean you guys run it for low load cruising.
Old Sep 13, 2009 | 06:23 PM
mysql101's Avatar
I don't get the question.
A turbo car is just like a NA car when you're not in boost. So I'd expect ~15 AFR at cruise.
Old Sep 13, 2009 | 06:25 PM
Brettus's Avatar
Boosted Kiwi
Kane has a pretty good handle on this I think .
Can you post your closed loop table - I can't be sure which one it is in pro tuner .
Old Sep 13, 2009 | 06:29 PM
Mawnee's Avatar
I divide by zero
I know 14.7 ...but alot of people get away with going even a bit leaner for the sake of fuel mileage.
Old Sep 13, 2009 | 06:38 PM
mysql101's Avatar
yeah, you can do 16, but only if you aren't running a cat.
Old Sep 13, 2009 | 06:40 PM
Mawnee's Avatar
I divide by zero
pffft..whats a cat ?
My CL tables are essentially stock atm, I just lowered the exit RPM to 4200 and Exit loads down a bit to make sure it switches to my richer tables ahead of any boost. My o2 sensor has like a 1.7 second latency so I have to kind of predict the future with my fuel tables for safety. I had set my Throttle fuel gear tables really rich when I first put together my "super duper safe" tune and forgoten about them. Found those to be the cause of some low speed bucking
Old Sep 13, 2009 | 06:42 PM
mysql101's Avatar
don't let TeamRX8 hear you!
Old Sep 13, 2009 | 06:44 PM
thewird's Avatar
15-16 as long as its smooth and only in high vacuum.
thewird
Old Sep 15, 2009 | 04:20 PM
09Factor's Avatar
Original Turbo 'd Auto !!
14.7 - 16.2 @ 20-22 in mg.
No cat.
Old Sep 24, 2009 | 10:25 PM
chickenwafer's Avatar
Nope
Cruise at stoich.
Just put all your CL fueling tables to a Lambda of 1.00
Old Sep 24, 2009 | 10:32 PM
Kane's Avatar
Start at 15.2 and move to 14.7 at RPMS above 3500 and a Load above 30%
That is what I do... but 14.7 is always a good safe bet.
Old Sep 30, 2009 | 12:43 PM
Rote8's Avatar
No cat.
How many rpm is that at?
I get 20 in mg at idle and 22 in mg at a cruise if I am doing about 2K to 3K rpm
If I cruise at 4K (about 80Mph) I only get 16 to 18 in mg.
Still get 28 in mg on deceleration.
04Green
12
May 13, 2023 10:08 PM
MikeTyson8MyKids
Nov 12, 2022 11:54 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
dbarber
Jul 25, 2015 01:34 PM
