Low Budget Upgrades
Old Aug 24, 2009 | 10:16 AM
dgbowers's Avatar
Low Budget Upgrades
I recently bought an RX-8, and I've been looking to do some performance upgrades... but I'm in college and have limited resources. Any suggestions?
Old Aug 24, 2009 | 10:18 AM
mike[piston eater]'s Avatar
O' Let's do it.
remove vfad and filter walls and get a k&n drop in filter
Old Aug 24, 2009 | 10:21 AM
The Reverend's Avatar
That's a lie
You won't get any decent performance upgrades for cheap with this car. Search around for
exausts
intakes
midpipes
cobb accessport
Old Aug 24, 2009 | 10:22 AM
Renesis_Genesis's Avatar
find a rich girlfriend
Old Aug 24, 2009 | 10:23 AM
O' Let's do it.
or get some lowering springs and upgrade the handling performance ohhh
dgbowers's Avatar
Seems like the most viable option
Old Aug 24, 2009 | 10:25 AM
That's a lie
or get some really nice tires tbh
Old Aug 24, 2009 | 10:28 AM
dgbowers's Avatar
I bought some Goodyear Eagle GTs and put them on. Are those pretty decent?
Old Aug 24, 2009 | 10:32 AM
pdxhak's Avatar
Official Post Whore
You will not find any inexpensive HP upgrades for this car.
Old Aug 24, 2009 | 10:33 AM
O' Let's do it.
do the throttlw body bypass
Old Aug 24, 2009 | 10:37 AM
Huey52's Avatar
Registered Zoom Zoomer
Exactly. Best low cost bang for the buck. I wouldn't modify the stock filter box tho'. Just remove the VFAD and drop in a K&N flat filter. You'll have a noticeably smoother transition without the VFAD shutter hesitation around 4k rpm and more airflow with the K&N. You can also add the Racing Beat Duct to more directly intake ambient cold air to the filter.
Old Aug 24, 2009 | 10:41 AM
dgbowers's Avatar
Is there a diy guide for it?
Old Aug 24, 2009 | 10:43 AM
O' Let's do it.
yes its very easy , and the walls inside the airbox come out with a screw too so theres no hack job
Old Aug 24, 2009 | 10:44 AM
pdxhak's Avatar
Official Post Whore
Do not expect much if any gains by doing these mods...
Old Aug 24, 2009 | 10:46 AM
dgbowers's Avatar
Thanks for the input guys. Im probably just going to end up pinching pennies to get an intake or exhaust.
O' Let's do it.
not much gains but cheapest thing to do its basically free except for thr drop in filter which i got free, and throttle body bypass is like 10 buxs and worth it for a slightly better response
Old Aug 24, 2009 | 10:47 AM
O' Let's do it.
neither of whick will add power uless you get a midpipe
Old Aug 24, 2009 | 10:48 AM
dgbowers's Avatar
Can you post a sticky for the DIY
Old Aug 24, 2009 | 11:46 AM
O' Let's do it.
yeah lemme search it
Old Aug 24, 2009 | 11:56 AM
O' Let's do it.
diy vfad removal
https://www.rx8club.com/showthread.p...y+vfad+removal
diy intake box mod
diy throttle body bypass mod
https://www.rx8club.com/showthread.p...ody+bypass+diy
Old Aug 24, 2009 | 12:09 PM
Huey52's Avatar
And here's the Racing Beat Duct mating to the stock airbox DIY: https://www.rx8club.com/showthread.p...highlight=Duct
Note that you have to remove your front bumper to remove the VFAD. It's really pretty easy. You disconnect/remove the side marker lights (aka "corners'), undo a series of nuts above and below and lastly disconect the foglight connectors. There's a good DIY for the bumper removal as well. The first time you take off the bumper takes some time (noobie caution factor) but thereafter can literally be done in 10-15 minutes. Video and text:
https://www.rx8club.com/showthread.p...bumper+removal
Old Aug 24, 2009 | 12:11 PM
O' Let's do it.
thanks i forgot to tell him about bumper removal
Old Aug 24, 2009 | 12:15 PM
fastlaneracing's Avatar
Rotor User
Low budget and performance dosen't go together.
Give your car a nice maintenance instead, new coils, plugs, plug cables, oil, filter etc..
Old Aug 24, 2009 | 12:51 PM
Huey52's Avatar
I would agree in principle that true performance enhancements on the '8 cannot be done on a tight budget. But there are some things, such as VFAD removal, a more efficient air filter, a short shifter, better tires, etc. that can give a "butt dyno" feeling of enhanced performance. I believe the OP is aware that there's no free lunch and these "low budget mod's" are what he's looking for.
Heck, I'm on the opposite end of the spectrum from college days and still like a inexpensive 'feel good' mod when I can find it. Frugal Yankee in me I guess.
Old Aug 24, 2009 | 01:02 PM
Rotor User
You are right, there are some goddies there.
Im also a fan of most bang for the bucks and a good maintainend car is a fast car.
