Spark Duration
Old Aug 23, 2009 | 06:32 PM
auzoom's Avatar
Hmmmmmm.........
Spark Duration
Following on from a comment in the Coil Dwell thread, I have some questions on spark duration.
The main question I have is, is spark duration a function of the spark plug, the coils or the ECU?
I am guessing its the ECU. Depending on the answer I have a bunch of other questions.
Cheers
Andrew
Old Aug 23, 2009 | 06:46 PM
MazdaManiac's Avatar
Coils. The collapse of the field only takes a few microseconds and is not sustainable.
Old Aug 23, 2009 | 09:36 PM
auzoom's Avatar
Hmmmmmm.........
Awesome...thanks So now I want to find out if there is published data (like this http://www.dtec.net.au/Tech%20Articl...%20Testing.pdf) on spark durations and energy across different coils.
Old Aug 26, 2009 | 11:50 PM
madcows's Avatar
Auzoom, there should be plenty of data related to high voltage coils (not just auto specific) all over the net. But if you're trying to find data on a specific group of automotive coils, then it might be a bit difficult. Many manufacturers of aftermarket units specify their output energy and duration.
Old Aug 27, 2009 | 12:03 AM
auzoom's Avatar
Hmmmmmm.........
I have only managed to find a small amount of data from some independent tests like I posted up. I am an electronics dunce so while I would love to try the tests in that link I would probably electrocute myself!
tjohnmeyer
Sep 28, 2017 05:03 PM
Oct 3, 2015 09:51 AM
Danield97
Sep 30, 2015 05:59 PM
Jb4ker96
Sep 27, 2015 10:06 PM
