bleed brake sequence?
Old Aug 19, 2009 | 06:56 PM
c41250n's Avatar
is there a sequency to bleed the brakes on the rx8?
cause I know the subies needs to bleed the front first!
please let me know, thanks!
Old Aug 19, 2009 | 06:58 PM
expo1's Avatar
He's as bad as Can
Mc, rr, lr, rf, lf, mc
Old Aug 19, 2009 | 07:36 PM
c41250n's Avatar
if I don't chance the BMC, then I don't need to bleed that right?
Old Aug 19, 2009 | 07:48 PM
expo1's Avatar
He's as bad as Can
I quoted the shop manual. They only listed ONE method of bleeding the brakes.
File Type: pdf
Old Aug 20, 2009 | 12:00 AM
c41250n's Avatar
thanks
Old Oct 26, 2009 | 09:43 PM
kosoku's Avatar
How do you bleed the MC?
Old Oct 26, 2009 | 09:47 PM
Jon316G's Avatar
Grasshopper
Same way as you bleed the brakes at the calipers.
Old Oct 27, 2009 | 10:38 PM
kosoku's Avatar
Oh. There's a bleed screw for it?
Old Oct 27, 2009 | 10:52 PM
Jon316G's Avatar
Grasshopper
Yup
Old Oct 28, 2009 | 07:22 AM
tmak26b's Avatar
I think only the 04, 05 have it?
Old Oct 28, 2009 | 07:34 AM
Huey52's Avatar
Registered Zoom Zoomer
Even easier if you have Russell Speed Bleeders.
http://www.russellperformance.com/mc...domestic.shtml
btw: the MC is self bleeding (high point; open to atmosphere).
Old Oct 28, 2009 | 08:22 AM
Dive Bum's Avatar
IYAOYAS
Installing Power Slot rotors and Hawk HPS pads this weekend. Question: How much fluid does the system take? The reason I ask is I see online that there is 12oz... then 32oz, then a gallon. I really don't want to buy anymore than necessary for the job. Thanks in advance. Bill
Old Oct 28, 2009 | 08:30 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
32 oz will cover a full fluid swap with a good amount left over left over... if you're just change pads and rotors, you shouldn't lose that much fluid... I had enough left in the 32oz to change the fluid in my motorcycle too.
walmart had 4oz bottles of prestone DOT4 fluid which would cover that job. I would get 2 bottles if going that route...
Old Oct 28, 2009 | 08:33 AM
justjim's Avatar
justjim
If you are just changing pads and rotors you don't need to crack the hydraulic system. If you are just bleeding the brakes you can probably get by with half of a 16 oz bottle. If you are flushing the system with new fluid you can probably do it with a quart (32 oz)(liter) but might want some extra on hand in case you need more.
Old Oct 28, 2009 | 08:48 AM
Vyndictive's Avatar
good call... i had some fluid spill out of the MC when pushing the caliper pistons back in... that is really the only way to lose fluid.
Old Oct 28, 2009 | 08:51 AM
Huey52's Avatar
^ Yep. Always good to wrap a rag around the MC reservoir (cap ajar of course) when retracting the caliper pistons.
Old Oct 28, 2009 | 11:05 AM
Dive Bum's Avatar
IYAOYAS
Thanks for the advice guys... Though I don't do any track racing, we are looking at flushing the system when we replace the rotors and pads. I also notice that Prestone makes a synthetic brake fluid. They say it is recommended for anti-lock brakes. Is there any advantage to this over regular Dot-3 fluid?
Old Oct 28, 2009 | 03:02 PM
justjim's Avatar
justjim
There are 4 types of brake fluid out there, DOT3, DOT4, DOT5, and DOT5.1. DOT3 and DOT4 are glycol ether based and are safe for the RX8. DOT5 is a silicone based fluid and not recommended for the RX8. DOT5.1 is a glycol ether based fluid and was an attempt by the DOT to undo the fuckup of DOT5. All brake fluids are synthetic. DOT4 and DOT3 can be mixed, DOT4 has a slightly higher boiling point. If the car is only seeing street use regulaar DOT3 or DOT4 fluid is fine. If you are tracking the car on road courses you may want to try somthing like ATE Super Blue racing fluid (DOT4). See Brake FAQ https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/brake-faq-167264/ .
Old Oct 28, 2009 | 03:16 PM
Huey52's Avatar
DOT 5.1 is best if you want ABS surround sound. (couldn't resist)
Old Oct 28, 2009 | 08:32 PM
RA-Eight's Avatar
Scuderia
Off topic, but I'm troubleshooting a sound I notice since upgrading to the Racing Brake BBK.
Is this sound you're referencing an audible "click" coming from each side when first depressing the brake pedal?
Old Oct 28, 2009 | 10:22 PM
kosoku's Avatar
Thanks for clarifying! I just spent 20 minutes staring at my MC looking for that.
Old Oct 29, 2009 | 06:04 AM
Huey52's Avatar
There's really no need for it so they 'value engineered' it out in '06 and beyond.
Thanks for clarifying! I just spent 20 minutes staring at my MC looking for that [bleed nipple].
Old Oct 29, 2009 | 06:40 AM
Dive Bum's Avatar
IYAOYAS
@ justjim - Thanks man, I appreciate the advice.
Old Oct 29, 2009 | 09:12 AM
imput1234's Avatar
I ♥ Drifting!!!
Just like any car start with the furthest away from the mc, and go down.
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
