intakes which is better
Old Aug 17, 2009 | 08:35 PM
pineapplesoymilk's Avatar
pure sex
i now have a aem cold air on my 8 it sounds good and every thing but i do worry that when it pours which it has been alot latley that it will mess something up by being sucked in and i was wondering which is better a short ram or a full cold air for both power and reliability i have seen a few of you guys out their who have some sick short rams out their and i also no that short rams are louder so pleas and thank you.
Old Aug 17, 2009 | 08:37 PM
Jon316G's Avatar
Grasshopper
Stick with the AEM and don't worry about rain.
Just don't drive through a deep puddle that would submerge the filter.
Old Aug 17, 2009 | 08:39 PM
pure sex
i try not too but it has been raining soo feirce latley
Old Aug 17, 2009 | 08:40 PM
Jon316G's Avatar
Grasshopper
We get some good storms here in Ohio too.
I never had a problem with rain and the AEM intake.
Old Aug 17, 2009 | 08:43 PM
pure sex
yea i love it , it sounds so beastly but might just switch to a short ram only time will tell
Old Aug 17, 2009 | 08:44 PM
Jon316G's Avatar
Grasshopper
I switched to the Racing Beat and sold my AEM to a local.
If I could go back, I probably would have stayed with the AEM.
Old Aug 17, 2009 | 08:46 PM
Easy_E1's Avatar
A short ram is not a COLD AIR INTAKE. It will pull in hot air from the engine bay. Not a good thing. Stick with the AEM it's the best one out there. AEM makes a sock that goes over the filter that's suppose to keep water out. And large debris. You should not have any issue unless your in a foot and a half of water.
Old Aug 17, 2009 | 08:48 PM
pure sex
yea i have the sock that came with it on it since i installed it
Old Aug 17, 2009 | 08:49 PM
Jon316G's Avatar
Grasshopper
Suppose is the keyword there.
When I was cleaning the filter I "experimented" with the sock.
I sprayed a light stream of water onto the sock with a shower head.
It helps a little bit, but water will still get through.
Old Aug 17, 2009 | 08:54 PM
pure sex
what about those bypass vaulves i dont have one but i also hear they decrease the sound of the intake and the suction rate of the air also
Old Aug 17, 2009 | 09:21 PM
Z0oMzo0m's Avatar
dont worry about water.. I have mazdaspeed and Florida gets nasty rain storms, I drive in them daily in afternoons on highway going to work. Dont worry about getting it wet.
I just ASSUME after it stops raining, dont drive the car like you stole it. Keep the revs down and water wont get into the engine.
Old Aug 17, 2009 | 09:23 PM
Jon316G's Avatar
Grasshopper
FYI... getting water in the engine isn't the problem, its getting water on the MAF.
Old Aug 17, 2009 | 09:29 PM
Z0oMzo0m's Avatar
well yeah.. thats what i ment. Thanks for the fix!
Old Aug 17, 2009 | 10:22 PM
Brettus's Avatar
Boosted Kiwi
amen to that .
I'm really surprised the AEM does not have this problem . My filter is in a similar position and I had issues when it rained (before I did some mods). Maybe that sock thingy does the trick ?
Old Aug 17, 2009 | 10:23 PM
rodjonathan's Avatar
silent assasin
yeah i believe the sock thing is what does the trick i have an aem and have had no trouble with water but i dont have the sock on yet (dont have one looking for one) so i havent driven it in crazy heavy rain just to be safe
Old Aug 17, 2009 | 10:26 PM
Brettus's Avatar
Boosted Kiwi
I found when I was driving it was fine . Just when the car was parked in the rain for a while I had a problem . Water falls down from between the bonnet and the bumper ....
Old Aug 18, 2009 | 12:15 AM
Everyone I know who has the MS/AEM get there filters soaked and it has not rained here for months. Even in the cars wash they get wet. Not worth the risk IMO.
Old Aug 18, 2009 | 02:08 AM
Flashwing's Avatar
3-wheeler
Getting your filter wet doesn't pose any risk to the vehicle. You cannot hydrolock the rotary engine so even if you drove the motor through a lake you could start the motor provided everything else worked.
I digress...
I have gotten my filter pretty soaked a few times when it's rained really hard in Phoenix. What ends up happening is water is detected by the MAF as air and it causes the grams/sec readout to shoot through the roof.
With a wet filter I could see 350+ grams/sec on the MAF which for an N/A RX8 is physically impossible. What ends up happening is the PCM tries to add fuel to account for the air and it ends up running stupid rich and causing incomplete combustion.
This doesn't actually happen until I drive above 6,000 RPMs so even if your filter is wet just take it easy in the rain and you won't have any problems. Maybe take the whopping 5 minutes to remove your MAF and clean it.
No risk running the AEM.
Old Aug 18, 2009 | 02:32 AM
Brettus's Avatar
Boosted Kiwi
I digress...
Under boost I thought I noticed the exact opposite IE ran lean - which is very bad . I'm not 100% sure what I saw now that you say that ......
Old Aug 18, 2009 | 02:33 AM
Flashwing's Avatar
3-wheeler
Wow, I can't say I've ever seen that happen. In my case it's always gone rich and even thrown a CEL for the MAF being out of range.
Old Aug 18, 2009 | 02:43 AM
Brettus's Avatar
Boosted Kiwi
I did look at my wide band and saw it was running one or the other . Can't remember . Enough to cause violent misfires - not good .
Old Aug 18, 2009 | 02:58 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
Had racingbeat intake and duct for 2.5 years and loved it! Now I have AEM and I still love it! Can't go wrong with either one, but AEM would be better if you plan on going greddy turbo in the future.
Old Aug 18, 2009 | 05:28 AM
pure sex
yea i do plan on turboing it thanks for all the intell
Old Aug 20, 2009 | 03:00 PM
8upbad's Avatar
Jared
I'm not trying to be an *** but your question makes me think you should do a little research on engine performance. You can not upgrade one part and get any kind of good results. If you get an intake you will get a wooop sound and worse gas millage. Engines are made to work with the parts they have. You can upgrade everything or nothing IMHO. If you want a real noticeable upgrade that will maybe even lower your 1/4 time by a whole second (not that I like drag racing its just a good point of reference) get really really good tires. Otherwise save your damn money for that FI and do it right.... like me =)
Old Aug 20, 2009 | 04:14 PM
04RX8man's Avatar
Rotary Powered Countryboy
just remember colder air is denser air which makes more power...so AEM/MS is the best beccause they are true "cold air intakes".....
