OIL FILTER Change Interval
Old Aug 13, 2009 | 05:49 PM
TX OIL FILTER Change Interval
I'm pretty much done researching engine oils for the new motor and I have made a decision on 0W-30 Castrol Syntec (GC). As usual I will change my oil every 3,000 miles. But in reading a lot lately I have read that the general consensus is that a good oil filter (K&N for me because of the nut on top) should last 10,000 miles at least. What are your thoughts? I have always changed the oil filter every 3k just because the cleaner the filter the better but i don'tthink it helped the Renesis any in terms of longevity. What are your thoughts? Sure would't hurt to save $12.00 here and there.
Old Aug 13, 2009 | 06:11 PM
invasion08's Avatar
Today many car company's oil change intervals are between 3k and 10k miles. So your oil filter should be able to last, atleast 2-3 oil changes. I like to change my oil and oil filter together just to be safe. But there is no reason why your oil filter should not last longer than 3k. I also use K&N
Old Aug 13, 2009 | 06:13 PM
invasion08's Avatar
I know this has been on the talk about before, but to make oil changes even easier, you should check this out: http://www.quickoildrainvalve.com/
Old Aug 13, 2009 | 06:19 PM
Socket7's Avatar
ಠ_ಠ
I think you'd be good to change the filter every other time you change the oil.
How much per year do you spend on oil filters VS. double mocha lattes? It might be more economical to change the filter every time and cut down on ordering coffee from starbucks/ consumer vice of your choice instead of changing the filter less frequently.
Old Aug 13, 2009 | 07:59 PM
I would change the oil a bit less often and change the filter every time.......
A good synthetic should last 5K miles....
Old Aug 14, 2009 | 12:40 AM
Yeah the amount of money I spend on filters is nothing so I'll just freakin' replace it every time.
Old Aug 14, 2009 | 12:43 AM
Do you need the valve and the adapter for the RX-8?
Old Aug 14, 2009 | 11:51 AM
invasion08's Avatar
yes you do
Old Aug 14, 2009 | 12:10 PM
byez's Avatar
3,000 miles on a PAO synthetic like GC? Give me your used oil and I will use it for another 3,000 miles.
I do 3,000 miles on the cheapest dino I can find and yes I do sleep ok at night.
Old Aug 14, 2009 | 12:24 PM
as others have mentioned, the filter SHOULD EASILY be able to last the 3,000 miles but why take the chance.
I just change them both every time
Atkins Rotary has great prices on the filters
Old Aug 14, 2009 | 01:15 PM
Filter is cheap, even stock filters are pretty good (I got mine for like 3-4 bux) I have a bunch of stock filters at home, cuz most my other cars uses the same size so why not ?
K&N is good too, I have a few left, oil change due soon ... hmm what should I use hmm ...
for those quick drain valve, I had one, but I took it out after 3 oil changes, its too FUXKING slow, plus the valve is a bit higher so some oil will stay in the pan ... I dont want that, plus oil drain plug gasket are cheap so I went back old school.
Old Aug 14, 2009 | 02:58 PM
Nubo's Avatar
Lubricious
The stock filter is not just pretty good, it is freakin' fantastic.
Old Aug 17, 2009 | 09:40 AM
TX
Good for you. You haven't had three engines and you don't live in San Antonio where we are almost at 50 straight days of 100F plus degree weather. My second motor ran Castrol GTX with OIC of 3,000 miles and it only lasted 72k.
Old Aug 17, 2009 | 09:53 AM
Huey52's Avatar
Registered Zoom Zoomer
Oil can last a long time and fllters can last a long time, in theory. But as the lifeblood of your vehicle there's almost nothing better you can do for it than regular oil/filter changes.
There's no point in continuing to use a dirty filter with newly changed oil. The filter was made to sacrifice its life for the good of the engine.
Change the filter every oil change, which in my case (and many others), is 3k miles.
I use Castrol GTX. There's not much point in paying more for long duration synthetic oil when I don't go long duration between changes.
Old Aug 17, 2009 | 11:55 AM
I think his point is that he did use dino but his engine still died. so he is trying to see if Synthetic will make his engine last longer.
To me, this is really hard to tell, all engines are different especially a rebuild, they will have some used parts in there, this one could be a used e-shaft, the other one could be used rotor, etc.
so yeah, its hard to tell ...
Old Aug 17, 2009 | 12:10 PM
ken-x8's Avatar
If it's a proper rebuild, it does not matter whether any particular parts are new or used. Whatever goes into a rebuilt engine has to match new part tolerances. IMHO, any issues with a rebuilt or new engine would come from assembly, not parts.
The theme of this thread is very nostalgic. Back when oil was changed every thousand miles it was common to do the filter every other change. But it's been pretty standard to change the filter with the oil for quite some time.
Ken
Old Aug 17, 2009 | 03:29 PM
04RX8man's Avatar
Rotary Powered Countryboy
I was taught once that your standard OEM replacement filter(for any vehicle) should last about 6k miles but I personally and everyone I know just change it everytime....you're puttin clean oil in there so just put a clean filter to keep that oil clean as long as possible
Old Aug 17, 2009 | 04:12 PM
Exactly. Castrol GTX 10W30 with OIC's of 3k didn't really help me at all so I'm running GC 0W30 and premixing. I will be tracking my car more now so I wanna try and save money where I can since I will change my oil after each track day.
Old Aug 17, 2009 | 07:57 PM
ken-x8's Avatar
What didn't it help with?
Ken
Old Aug 17, 2009 | 08:01 PM
04RX8man's Avatar
^the longetivity of his motor!
Old Aug 17, 2009 | 11:13 PM
ferg's Avatar
Check out this oil filter
Old Aug 17, 2009 | 11:29 PM
TX
Ken
Religious oil changes every 3k (as usual) with heavier 10W30 didn't help and my motor lost compression after 72k. Other than premix or run synthetic I did everything by the book (yes that bitch was red lined everyday). The car is paid off so now I will see how long this one lasts. Recently I have decided unless something major aside from normal wear and tear happens, I am keeping this car and sometime next year it will retire from DD duty and become a weekend warrior.
Old Aug 18, 2009 | 12:17 AM
Easy_E1's Avatar
Good.
Old Aug 18, 2009 | 01:13 AM
fastlaneracing's Avatar
Rotor User
There is absolutely no reson to change the oil and not change the filter at the same time.
Old Aug 18, 2009 | 09:33 AM
ferg's Avatar
yeah
