**Exclusive Canadian Reseller** Idemitsu Racing Rotary Fuel Lube - Synthetic Blend
Old Aug 11, 2009 | 09:00 AM
streetpower's Avatar
http://www.idemitsu-usa.com/page_207.htm
Idemitsu Racing Rotary Engine Oil 10W-30
(Full Synthetic)
Formulated Specifically For High Performance Rotary Engines
Contains Special Molybdenum Agents to Reduce Friction, Which Increases Horsepower & Torque
Improved Sealing Performance
Minimizes Exhaust Port Clogging
Superior Shear Stability
Exceptional Wear Protection & Durability
$14.00
Idemitsu Racing Rotary Engine Oil 20W-50
(Full Synthetic)
$14.00
Idemitsu Racing Rotary Fuel Lube (Premix)
(Synthetic Blend)
Designed For Use In Gasoline Engines Only
Provides Additional Wear Protection For Apex Seals, Side Seals, etc.
Keeps Fuel Injectors Clean For Reduced Maintenance
Reduces Friction
Application: 1/2 oz. Per 1 Gallon of Gasoline
$14.00
Idemitsu Racing MTF/Gear box Oil 75W-90
Formulated Specifically For High Performance Gearboxes
Enhanced Film Strength Provides Excellent Durability and Wear Protection
Advanced Extreme Pressure Additive Package Improves Performance Under High Load Conditions
Superior Shear Stability Ensures Viscosity Retention Under High Stress Operations
Provides Smooth Shifting Across All RPMs
$14.00
Attached Thumbnails **Exclusive Canadian Reseller**  Idemitsu Racing Rotary Fuel Lube - Synthetic Blend-r10w30l.gif   **Exclusive Canadian Reseller**  Idemitsu Racing Rotary Fuel Lube - Synthetic Blend-r20w50l.gif   **Exclusive Canadian Reseller**  Idemitsu Racing Rotary Fuel Lube - Synthetic Blend-premixl.gif   **Exclusive Canadian Reseller**  Idemitsu Racing Rotary Fuel Lube - Synthetic Blend-75w90l.gif
Old Mar 12, 2013 | 05:15 PM
warrenchu's Avatar
Hi I am interested on the Idemitsu Fuel Lube which I used to order from State.
the price you are selling is included shipping to Toronro ?
or I can come to pick it up.
drebbrnator
Dec 27, 2018 07:02 PM
BigMikeATL
May 26, 2016 12:31 AM
dafiltafish
Aug 21, 2015 06:56 PM
Obivious
Jul 29, 2015 05:57 PM
