Oil cooler hose popped.
Old Aug 3, 2009 | 11:06 PM
Its not common.
cooling hose for transmission? i guess you have an AT ?
Hmm, just stick it back in, add some ATF back and good ?
Old Aug 5, 2009 | 08:58 AM
ken-x8's Avatar
It can take a while for oil on a hot surface to evaporate. You might try spraying it down with solvent (maybe brake cleaner) when cold ...which would then have a shorter burn-off time.
What was the failure like? Hose need to be replaced, or was it just a slip-on end that needed to be re-clamped?
Good to hear of an 8 with 130,000 miles.
Ken
Old Aug 5, 2009 | 09:05 PM
It can smoke up to a week and a half if it gets into the all the cracks.
Old Aug 8, 2009 | 09:01 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah it'll burn off eventually!
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
