WANTED Passenger side tail light assembly
Old Aug 3, 2009 | 11:12 AM
dirtyd's Avatar
I am a virgin
WANTED Passenger side tail light assembly and driverside window motor
does anyone have one that in good condition?
desouza.darryl@gmail.com
Old Aug 3, 2009 | 12:36 PM
PaQuiN's Avatar
Ballin'
I need one too. Why do you need one? If your getting moisture build up in it you can buy a gasket to fix that at a Mazda dealer. There not cheap, about 30 bucks a side.
I need one because I was too cheap to buy the gasket so I punched a hole in the bottom of the light to drain it. Believe it or not this trick worked pretty good. However...I broke a retainer clip taking it out and putting it back in so many times, lol...good ol silicone should hold it for a bit.
Old Aug 3, 2009 | 06:26 PM
dirtyd's Avatar
I am a virgin
i dried the moisture with a hair dryer for the second time and re-seal it with more silicone, after I re-installed it i noticed that i put too much heat to it and now there is alot of cracks all over the lens
Old Aug 5, 2009 | 08:32 PM
dirtyd's Avatar
I am a virgin
now I also need a window motor driver side
Old Aug 9, 2009 | 08:52 PM
rx8shift's Avatar
hahaha I also dried mine too much with the hair dryer causing damage, the plastic actually melted on the inside of the tail light and the bulb will not go back in all the way.
Crazy.8
Apr 18, 2017 03:17 PM
SayDfuse
Aug 3, 2015 10:41 PM
ripigs
Aug 2, 2015 10:44 PM
marc2820
Jul 26, 2015 10:47 PM
ColeParkerrr
Jul 23, 2015 10:50 AM
