Rear Wheel Hub locknut size?
Old Jul 26, 2009 | 05:57 PM
Wind Dance's Avatar
Central Valley RX8
Question Rear Wheel Hub locknut size?
Does anyone know the size of the locknut used on the rear wheel hub?
To clarify, I'm replacing my lug studs and after removing the brake rotor off. I find out that i'll need to remove the hub in order to gain enough room to knock out the old studs. Largest socket I have is a 30mm and this is even larger. ANYONE?
Old Jul 26, 2009 | 06:08 PM
StealthTL's Avatar
Are you sure??
There is usually a gap in the back plate that lets you knock the studs back out, one at a time......
S
Old Jul 27, 2009 | 04:23 AM
Wind Dance's Avatar
Central Valley RX8
The fronts are clear, but the rears have very little room behind them. Seems like this would be my only option. I searched some threads about it and it seems like everyone stated that it has to be removed. Just not sure what size the nut is.
WingleBeast
22
May 23, 2016 09:22 PM
Kahl
Aug 20, 2015 11:49 PM
Shinka84
Aug 19, 2015 04:55 PM
Brandonien
Jul 30, 2015 12:33 PM
