Vibrations: bad engine mount symptoms?
Old Jul 21, 2009 | 08:58 PM
JinDesu's Avatar
went back to srsly broke
So I just got my car back from the shop after my accident about a month ago. I was driving it, and noticed these symptoms:
1) While the engine is in park, neutral, or idling in drive, there is an increase in vibrations. It's enough to make the glovebox rattle a lot.
2) While the engine is under load (normal driving), there is no increase in vibrations.
I saw that a lot of replies for engine vibrations are to change the coils, change the spark plugs. Can anyone give me the symptoms for those?
The reason why I believe it's the engine mount over the coils/ignition is because my car only has 1800 miles on it. Admittedly, it's an 06, and I do not know if coils/ignition degrade when unused. Also, the accident I had leads me to believe impact has caused damage to the engine mount. Does anyone have additional insight into this?
Old Jul 21, 2009 | 09:25 PM
cyclone1208's Avatar
Its your engine mounts....get em change and yur back to new
Old Jul 21, 2009 | 09:27 PM
JinDesu's Avatar
I'm bringing the car back to the shop tomorrow to do that. I wanted as much info as I could get on this issue so I can explain it to them. Thanks for your input.
Old Jul 21, 2009 | 09:34 PM
Remember you have to drive the car a few cycles for the ECU to re-program itself.
What RPMs was that car idling at?
Old Jul 21, 2009 | 09:37 PM
JinDesu's Avatar
Cold start 2krpms. After the engine was warmed, around 800-1000rpms. That hasn't changed from before the accident.
What is a few cycles? On off cycles?
Old Jul 22, 2009 | 01:16 PM
Maaz's Avatar
its the engine mounts, you need new ones.
vapor2
Nov 3, 2020 03:38 PM
Dokuji
Nov 1, 2016 02:51 PM
rotorocks
47
May 11, 2016 03:23 PM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
