Does RX-8 heater core let you cool engine w/ heater?
Old Jul 6, 2009 | 02:44 AM
Spirograph's Avatar
If the RX-8 overheats, can you use the heater on high to suck heat from the engine bay to cool the engine?
Old Jul 6, 2009 | 06:31 AM
you can
but you shouldn't overheat in the first place.
Old Jul 6, 2009 | 12:28 PM
04RX8man's Avatar
Rotary Powered Countryboy
as said yes....I believe some of the SW guys out there that are running the AP someone posted a thread or a post at somepoint with their reading with and without the heater on and there was a noticeably difference (since they could monitor it almost exact with the AP) but I don't see the need to do it on a daily basis....i think it was just a few degress....10 MAX
Old Jul 6, 2009 | 04:40 PM
Nubo's Avatar
Lubricious
It should only make a significant difference in a situation where the cooling system is not coping. It gives you a small margin of extra cooling in that case.
Old Jul 6, 2009 | 06:32 PM
It works for any car.
Old Jul 6, 2009 | 11:25 PM
ASH8's Avatar
Super Moderator
It will give temporary relief as you are opening up the heater tap which lets out Cold Coolant through the system, and it will take some heat out, but only marginal.
Old Jul 7, 2009 | 12:49 AM
Spirograph's Avatar
AZ
Yeah, I don't plan on overheating, but I live in Phoenix ... so it's always good to know in advance. I had read that that trick doesn't work very well for newer cars like it does old cars; I think it's the temperature controlled cars that don't work as God intended.
Old Jul 7, 2009 | 10:04 AM
Nubo's Avatar
Lubricious
If I were in a perenially scorching climate, I'd look into the modifications by MazdaManiac, who iirc, installed an auxiliary radiator. It's the only mod I've seen than seemed to make a serious improvement in the car's ability to shed more heat when the heat load is very high. Using the heater core as an auxiliary radiator isn't a good long-term plan
Old Jul 7, 2009 | 04:59 PM
Actually the radiator is from Charles R Hill
Old Jul 10, 2009 | 06:28 PM
I'd rather roast in hell for all eternity than turn on the heater on a hot summer day to keep a rotary engine cool
RevMeHarder
Jun 1, 2026 02:30 PM
Jesus Martinez
44
May 6, 2025 08:09 AM
coolcars44
Nov 29, 2017 05:45 PM
bxb40
Nov 6, 2016 07:14 PM
mazdaverx7
Jul 21, 2015 07:31 PM
