Sticky Goo?
Old Jun 22, 2009 | 01:03 PM
Kawsim's Avatar
Qasim
Sticky Goo?
Where can i buy some sticky goo or whatever it is that holds the emblems on? I took them off to paint them and i got a double sided adhesive tape kinda thing but its way to thick.
Old Jun 22, 2009 | 07:29 PM
pyroshock's Avatar
A good bet would be something like rubber cement. You apply a very thin layer to the surface your applying it to and a very thin layer to the back of the emblem. Wait a few seconds so they get a little tacky and then firmly press the emblem on the surface. It will take a few hours to reach maximum strength but it should hold through anything you'll see on the road (including water). You can also rub off any extra cement.
Just make sure you prep both surfaces. Cleaning them thoroughly will create a much better surface. If you are really worried about adhesion ligthly scratch/score the contact surfaces to increase the surface area.
Old Jun 22, 2009 | 07:43 PM
ken-x8's Avatar
How were the emblems attached in the first place? Glued straight on, or held with double sided tape?
If you browse at Autozone or Pep Boys or a similar place, you should be able to find thinner double sided tape or adhesive that's meant to hold trim on.
Ken
Old Jun 22, 2009 | 09:21 PM
bose's Avatar
Reginald P. Billingsly
Automotive adhesive tape, it's usually in the paint isle at autozone/checker your choice. Made by 3M it may seem a little thick but it's the best stuff you can get.
Old Jun 22, 2009 | 09:32 PM
05rex8's Avatar
sold the 8... :(
there is an emblem adhesive that works great as well
the double sided tape works, but it can be irritating to use because you have to trim it perfectly
http://www.autobodytoolmart.com/3m-p...1-p-10392.aspx
edit: I have seen this stuff in auto parts stores in the spray paint/auto body area
Old Jun 27, 2009 | 02:44 PM
iLikeEatPoo's Avatar
The Great Dick
you can try to use clear window sealant or rtv black. both seemed to work for me.
rotarywanker
Dec 8, 2022 05:56 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
Dokuji
Nov 1, 2016 02:51 PM
robd1337
Jul 31, 2015 09:35 PM
dmengel
Jul 18, 2015 09:35 AM
