RX8 R3 aftermarket parts
Old Jun 21, 2009 | 12:05 PM
rx8shinka's Avatar
Hello,
I was wondering if any of you know of available aftermarket parts for my car?
if so, post the link on here for me, Thanx
exhaust?
cross drilled and slotted rotors?
intake?
2009 RX8 R3 (Black)
Old Jun 21, 2009 | 03:32 PM
Fanman's Avatar
Welcome to the board. check out www.racingbeat.com. They make some great parts for our cars. Powerslot makes the slotted rotors for our cars, though our stock brake system is very good already. I would recommend stainless steel brakelines first, it will help your brake pedal more.
Old Jun 21, 2009 | 07:49 PM
rx8shinka's Avatar
sweet Thanx for the link !!! I like the cross drilled and slotted mainly for the amazing appearance, And I like how they keep the pads cooler
Old Aug 4, 2009 | 12:36 PM
adam_mc's Avatar
does all 08 parts fit on the 09 R3 without any problems??? like intakes and exhaust? most manufacturers list their items up to 08.
just curious
Old Aug 4, 2009 | 01:21 PM
Charles R. Hill's Avatar
Owner of BHR
Are you interested in simply swapping parts out for the sake of doing so or are you trying to improve upon the performance of the RX-8? The two fundamentals have completely different pathways and different costs associated with them.
Old Aug 4, 2009 | 05:29 PM
RX8pwnage's Avatar
RX8. Yeah, I get it.
There are '08 parts that will not fit on '09 R3. Underdriven water pulley is one part I recall off the top of my head. There are more. Make sure you do your research and be sure of what you are buying before you do. Id stick to ordering '09 parts and you will be good. Everything in my sig is aftermarket for R3. Good luck and have fun!!!!!
Old Aug 5, 2009 | 08:26 AM
adam_mc's Avatar
mainly i was interested in basic bolt-ons for the 09, such as a CAI and CBE but no one lists anything for the 09. i just didn't know if there was any significant changes from 08-09 that would prohibit these add-ons or would make the car run bad (new to the rotary).
Adam
Old Aug 5, 2009 | 08:55 AM
Owner of BHR
I understand that but here is my concern; if you want to focus on the driving aspects of the RX-8 you may end up wasting a lot of money on stuff that is of no consequence with this car.
Those of us whom have been around for a while with this car tend to suggest people get the RX-8 on a racetrack for a while so they can see just how awesome this car really is. Once they get a feel for the capabilities of the car (and themselves) they have a better idea of what they want to do for mods.
On the other hand, if you simply want to "dress" the car up and make a bunch of mods you run the risk of not only spending money but also of making the car perform worse.
Intakes generally provide no improvement to airflow (but some of them will make matters worse) and cat-backs are only a "style" decision and you can go with whatever sounds best to you.
Old Aug 5, 2009 | 10:45 AM
deadphoenix52's Avatar
meh.
cross drilled will crack and there is less surface area for braking. get slotted only.
Old Aug 5, 2009 | 11:06 AM
Or dimpled/slotted. Stick with doing research and you should be okay.
Old Aug 5, 2009 | 11:12 AM
rodjonathan's Avatar
silent assasin
the dimpled are really cool looking and are stronger than cross drilled
Old Aug 5, 2009 | 01:13 PM
ILoveFI's Avatar
Adam
My advice, if you are just wanting to do 'simple bolt-ons' save your money. Pretty much everything costs more than its worth unless you are doing full set-ups like a full exhaust, midpipe, intake, getting a cobb accessport so it will actually yield maybe 2-3 more hp
The best way I recommend spending money is on the suspension. Save up the money from the bolt ons, get some shocks/springs or coilovers. I did that on my miata and that thing damn near dominated anything in the twisties.
Old Aug 5, 2009 | 03:55 PM
meh.
yeah. dimpled will give you the look without compromising the structural integrity of the rotor.
Old Aug 9, 2009 | 07:14 PM
RX8pwnage's Avatar
Small FYI:
Found out the other day that previous years oil filler caps do not work on R3. Most likely not any 09 as they have changed how the cap screws on. Sigh.
Old Oct 25, 2009 | 09:52 PM
superman28's Avatar
just installed an aem cai on my 09
Old Oct 25, 2009 | 11:18 PM
plain ole wanker's Avatar
wankel my wanker
this why we need series 2 topic list
Old Oct 26, 2009 | 07:20 AM
michaelsk8er's Avatar
Be careful with any exhausts systems. The 09 exhaust is different. I know the cat seems to be different since installing my header. Also I believe the tips are further apart. The shifter and transmission in general is different for out cars.
I would recommend checking out the changes on the 09 thread in the Tech Info section. It has a lot of the changes documented.
Old Oct 28, 2009 | 02:21 AM
pcs's Avatar
pcs
hey rx8pwnage - are you running the RB with the twin tips? or the single tips?
Old Oct 29, 2009 | 08:40 PM
RX8pwnage's Avatar
dual singles
Old Oct 29, 2009 | 09:44 PM
all the Japanese aftermarket companies
Old Nov 3, 2009 | 11:49 PM
relvis's Avatar
i just bought a new 2009 r3 as well, and i'm real interested in lowering the car, but again i can't seem to find any listings for lowering springs any newer then 08. does any one know if the springs are the same on the 09 r3 as the previous models, i know the shocks are different but what about the springs?
Old Nov 4, 2009 | 09:55 AM
PTDragon's Avatar
R3
Is the 09 hood the same as older 8's?
Old Nov 4, 2009 | 11:16 PM
Wheeldog's Avatar
Yup
Old Nov 18, 2009 | 01:02 PM
pcs's Avatar
pcs
i don't know about you guys - but i don't really think my r3 needs any lowering. The ride height from stock seems fine and looks good w/ the wheels...
I think I'm going to track or auto-x the car before I start flipping around suspension pieces... this way I will know and feel the difference w/ each part that I add on...
Old Nov 18, 2009 | 03:14 PM
kersh4w's Avatar
Hit & Run Magnet
racingbrake - 2 piece floating rotors. aluminum hats.
yeah, now thats pimp.
