Oil LEAK - Please Help me
Old Jun 20, 2009 | 04:59 PM
NYC Drift King's Avatar
Supercharged by Pettit
How do I fix this?????
Old Jun 20, 2009 | 05:08 PM
expo1's Avatar
He's as bad as Can
you either need a new oil cooling line or the cooler itself. If your still under warranty the dealer will take care of it. If not you will need to buy the part and replace it. Its not that big of a job. I would clean that up and see if you can tell where the leak is coming from.
Old Jun 20, 2009 | 05:14 PM
chrism's Avatar
Misfit Moderator TnC
omar we can fix that in my garage.....but your buying the sand to dry the floor with......
Old Jun 20, 2009 | 05:22 PM
dozer's Avatar
on his 3rd rx8
do it! and take pics , pics soon to come of "dozers driveway", 2 1/2 spring instals, a cold air intake install, and 2 power steering issues knocked out with in 2 weeks
Old Jun 20, 2009 | 05:25 PM
Chris are you available tomarrow?
Old Jun 20, 2009 | 05:27 PM
I have 62000 miles so im pretty out of warrenty =[
Old Jun 20, 2009 | 05:31 PM
Helghast7's Avatar
F yo couch!
you might be able to put some sealant on the bolt to prevent it from leaking, at least temporarily to stop it from leaking
Old Jun 20, 2009 | 07:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
wipe it off and try to find exatly sure where it's leaking before i would do anything....
Old Jun 20, 2009 | 08:01 PM
it seems to be coming from the silver bolt.
Old Jun 20, 2009 | 08:05 PM
chrism's Avatar
tomorrow is fathers day.....tina got me going over to her parents....you sure if its the line or the cooler?
Old Jun 20, 2009 | 09:15 PM
its a brand new cooler so I'm pretty sure its the line or bolt...
Old Jun 20, 2009 | 09:26 PM
expo1's Avatar
He's as bad as Can
New Cooler?? What's the story behind the new cooler?
Old Jun 20, 2009 | 10:12 PM
chrism's Avatar
yeah howd that happen?
Old Jun 20, 2009 | 10:40 PM
Winning 8's Avatar
Hot Pit
did you change the new cooler with new washer??
Old Jun 21, 2009 | 01:44 AM
new crush washers?
Old Jun 21, 2009 | 09:00 AM
yeah why did you buy a new cooler?
it seems that you installed it wrong. (or its not secured)
put some high temp RTV around the bolt should do the trick, make sure its the one that has high oil resistant and support up to 600F
Old Jun 21, 2009 | 11:56 AM
04RX8man's Avatar
^agreed.....prob something u did when changing the cooler
Old Jun 29, 2009 | 07:45 AM
Hey thanks guys 4 real.
Old Jun 29, 2009 | 09:32 AM
Looks like its missing the inside crush gasket??
Azki23
Jun 27, 2018 03:48 PM
WranglerFan
Nov 5, 2017 09:35 AM
Tsurugi
Sep 7, 2015 08:27 PM
