DIY: How to Remove Foglight Housing and Bulb Reflector
Old Jun 15, 2009 | 11:29 AM
416to212's Avatar
Utopia Taco Bell
This is a DIY for how to remove the foglight housing and the bulb reflector.
I wanted to remove the bulb reflector inside the foglight housing because I wanted my foglights to project further and brighter (like our Euro brothers). I'm also running modified H11 bulbs in my foglights so that I have more lumens compared to the stock H9 bulbs. There is a DIY for this mod on the boards too.
I don't know if this has been done before but this how to is strictly pictorial. I don't know why I can't [img] tag these photos in the DIY section here, but it's annoying since pictures are worth 1000 words...
Old Jun 15, 2009 | 11:33 AM
cyclone1208's Avatar
Or take the whole front bumper off........if you are too lazy to take off the wheels
Old Jun 15, 2009 | 11:45 AM
Alexb's Avatar
desperately needs a drop
Good DIY..
Oh, and take the bumper off if you are too lazt to take the wheels off?
If I remember correctly, the bumper is a much bigger pain.
Old Jun 15, 2009 | 11:54 AM
Originally Posted by Alexb
Good DIY..
Nah.....just need a flat head and a screwdriver compared to jacking up the car takin the wheel off and unscrewing those annoying wheel well clips.......just my two cents
Old Jun 15, 2009 | 03:46 PM
416to212's Avatar
Utopia Taco Bell
Removing the front bumper isn't too difficult but I would strongly suggest that you follow the above DIY for just removing the foglights because it's less less time consuming and easier.
As for the clips? I hardly find them annoying if you know what you're doing.
Old Jul 21, 2009 | 03:48 PM
Tex8's Avatar
nice instructional, was needing to replace my driver's side foglight and this provided a good reference for removing it
thanks
Old Jul 22, 2009 | 06:06 PM
EMart11b's Avatar
Bang Bang
I've been meaning to do this, I was going to bake em open and unscrew it though. Maybe I'll do it this shortcut way.
Old Jul 27, 2009 | 08:58 AM
Thumper3322's Avatar
Good DIY!
The top screw is a bitch tho, I had to undo half the front bumper to get my hand in to get that screw off.
Old Nov 4, 2009 | 06:31 PM
van's Avatar
van
My passengers side stock H11 fog-light bulb is dead, and needs to be replaced. The manual says to crank the wheel fully to the left, and remove the grommets in the wheel well, and peel away the shield to access the fog-light assembly. But it seems like it would be difficult to access the fog-light without removing the wheel.
Has anyone here replaced the fog-light bulb without removing the wheel?
Old Nov 10, 2009 | 08:40 PM
EpicDynasty7's Avatar
EpicDynasty7
yes i had to replace a light not even a month ago. all i did was jack the car up, turn the wheel all the way to the left, undo some pop rivets and there it was. its a pain tho. i would recommend taking the wheel off.
Old Nov 30, 2009 | 11:18 AM
schiraldi's Avatar
taking hte wheel off is much better than cranking it "out of the way" - its a major pain in the *** that way cuz you can't get up there to work on it.
anyone know if this mod is "illegal" aka would result in a fix it ticket? I've got some LED's i wanna put in that are just a hair too long to fit in with the reflector there.
thanks
Old Nov 30, 2009 | 12:44 PM
EMart11b's Avatar
Bang Bang
thanks
It's not illegal as long as the color is legal. The Euro spec cars don't have them from the factory.
Old Nov 29, 2010 | 01:34 AM
dalllas304life's Avatar
yes i always just "reach around" from the front middle and twist and remove the light bulb, be very carfull if you seriously nick the bulbs they will burst. good luck.
Old Dec 10, 2010 | 12:50 AM
Evilnissan's Avatar
This looks very easy compaired to what I had in my mind. Glass is busted out on the divers side fog.
Old Dec 16, 2010 | 08:39 PM
SynistaRX8!'s Avatar
SynistaRX8
Just did this to my car today, and I was very happy with the results. I lifted the car up and removed the front tires to do this. Total time on this was 30 min. Really easy to do, especially with this "How to" write up, which is really well done BTW. I use the H11 bulbs and the difference is remarkable. Good write up!
Old Dec 18, 2010 | 04:40 AM
willnordacgreen1211's Avatar
04 NORDIC GREEN RX8
doing this today due to saturday boredom.
Old Dec 23, 2010 | 05:10 AM
04 NORDIC GREEN RX8
did it, like it, done. my only advice is wear some gloves. i got a few little cuts from getting the reflector out, it gets sharp once destroyed lol.
Old Dec 23, 2010 | 06:15 AM
RotaryTherapy's Avatar
Did this, however took my bumper off, much easier ...
Old Jul 1, 2011 | 03:38 PM
LawDog's Avatar
K9
thanks great DIY. my fogs look a lot brighter
Old Aug 17, 2011 | 08:23 PM
yurcivicsux's Avatar
thank you so much>>>
Old Sep 4, 2013 | 07:05 PM
Jdmmazda's Avatar
Anyone know an easy way to disassemble the fog light housing? Replaced the bulb a couple days ago and the bulb exploded in the housing for some reason so now I gotta figure out a way to clean all the glass out of the housing... Any help would be greatly appreciated on how to do this!
Old Mar 31, 2014 | 02:32 PM
Darkning's Avatar
Thumbs up
Thanks so much for this! Did it yesterday and took almost an hour to break/crimp the reflector out of the first fog light housing, but after I figured out the method of pinching it with the needle nose pliers the second one was done in 5 minutes. Both of my factory fog lights went out within a day of each other, and so I replaced them with these.
I ended up taking the whole bumper off so that I didn't wreck something with the oil coolers while trying to reach the top screw.
Last edited by Darkning; Mar 31, 2014 at 02:34 PM. Reason: Added link to replacement lights.
Old Apr 23, 2015 | 01:07 PM
Enrique2014's Avatar
lol i did this and it worked for the first one, the second one troubled me a little more. I was trying to move the broken park with a screw driver and I may have accidentally moved it a bit to hard and it cracked my lens. -_- I still manages to get out the broken part but now I have a broken lens. Do you think it'd still work, like not affect the bulb once I plug it back in?
Old Jul 22, 2015 | 01:17 AM
Xuzax's Avatar
I did this to my Mitsubishi's foglights. But without that reflector the beam is not ver good. Much more dispersed. The whole reason that reflector is there is to create a beam. I have these LEDs too. If you guys know where to get these reflectors / deflectors please fill me in!!
thanks
Old Jul 22, 2015 | 01:20 AM
Xuzax's Avatar
If your lense doesn't have an actual hole in it. U should be okay. If you start seeing moisture behind your lense. You should replace the lense considering it is getting to your bulbs
jamespond24
Dec 1, 2015 11:11 PM
nferguson88
Oct 6, 2015 12:45 PM
SimonT182
Oct 2, 2015 10:33 AM
pjwermuth
Sep 28, 2015 11:36 PM
Learners_Permit
Sep 27, 2015 07:38 PM
