Low level coolant warning light
Old Jun 6, 2009 | 11:00 AM
marcika's Avatar
Question Low level coolant warning light
Hi!
I have an interesting problem. My car is a 04 MT.
Sometimes I get (totally randomly) the red coolant warning light on the dashboard.
It happens mostly in curves/downhills with higher speed. After 5-7 sec the light just disappears.
The car doesn't have any other problem, the coolant in the reservoir tank is on the highest level (it doesn't change) and the coolant is clean - I mean there isn't any oil there. I just had an oil change, and the oil was clean aswell.
My engine just has been replaced (under warranty), but I have this problem with the previous engine too. I drove the car with the new engine for ~1500 miles only. I didn't use it above 4500 rpms (and above 3000 before 700 miles).
Is it the sensor's fault?
Thanks for the help!
Marcika
Old Jun 6, 2009 | 11:09 AM
quazmosis's Avatar
Chode
If you don't think you're low on coolant it very well could be the sensor.
Old Jun 6, 2009 | 11:12 AM
You got a 04. so its most likely just a faulty sensor.
Its a very well-known problem.
like quazmosis said, if you're positive your coolant level is right you can just ignore it.
or if you hate the light so much you dont ever want to see it again, you can just disconnect the sensor. it will never show up again.
Old Jun 6, 2009 | 11:13 AM
marcika's Avatar
It is a bit above the "F" mark. (when the engine is completely cool)
Old Jun 6, 2009 | 11:14 AM
then its fine.
a tad over the F line is fine. but I seen some dumbass (not on a 8) filled his overflow tank all the way to the top and he was wondering why his car overheats ...
Old Jun 6, 2009 | 11:22 AM
marcika's Avatar
Thanks for the advices!
The light is very annoying but I don't want to disconnect the sensor. Yet.
It seems I have to ask the dealer to replace the sensor.
Do you know how much does it cost? (approximately)
Old Jun 6, 2009 | 12:29 PM
rx8cited's Avatar
marcika,
About $210 US - you have to buy the entire reservoir which has the sensor built into it. They do not sell the sensor alone. I had to replace mine.
Old Jun 6, 2009 | 01:37 PM
marcika's Avatar
It means it costs around 400$ in Europe...
Old Jun 12, 2009 | 08:23 PM
boizart1's Avatar
I have the same issue but mines always comes on and off like at 2 minute intervals EVERYTIME i drive the car.
Old Jun 12, 2009 | 09:05 PM
myriadshalaks's Avatar
rot8ing
why don't people search these things?
Old Jun 12, 2009 | 11:30 PM
ASH8's Avatar
Super Moderator
Just something else to observe that is totally normal, coolant expands and contracts...in other words when my car is fully hot and I turn engine off the coolant level shows about 1 cm (3/8 ths inch) over the "F" mark or line, once the car is stone cold it shows on the FULL mark or line....it expands and contracts.
So, if you are topping off your coolant, do so when your engine is stone cold (the safest way also with no pressure in the system) and only to the "F" mark of line.
Old Jun 13, 2009 | 12:14 AM
I have a brand new coolant overflow tank thats collecting dust.
I can sell it to you if you want, but of course you have to pay all shipping
Im sure it will be cheaper than 400 Euro ...
Old Jun 13, 2009 | 05:46 AM
marcika's Avatar
I asked my friend to get me one. It seems it will be around 200$. But not for sure.
If it will be much more expensive, I would be interested to buy your one. Of course I would pay for everything.
Thanks in advance!
drebbrnator
Dec 27, 2018 07:02 PM
SUKIEE
Oct 9, 2017 09:41 PM
atmd
Aug 19, 2015 12:43 PM
dmac1961
Jul 24, 2015 11:27 AM
RotaryRider
Jul 20, 2015 07:05 AM
