PESKY Cel Question Hope for a Resolve?
Old Jun 2, 2009 | 12:20 PM
Pico's Avatar
It's Complicated
For months now I've been getting a two CELs P0420 and P0111.
I'm running the Racing beat Intake & duct/ and have the Mazsport DR Mid Pipe.
I know that the P0420 is related to emissions and the lack of a Cat.
I know that the P0111 is related to the IAT (Intake Air Temp.) and the differences in temp. between the intake air and the exhaust temp.
However, I have gotten the P0111 since the install of the Mid Pipe. I have changed the MAF (IAT sensor is located in the MAF) not once but 3 times now in order to fix the P0111. Everytime I have changed the MAF I have removed the CEL with a scanner and disconnected the battery to do a reset.
Today I installed the 3rd MAF since this past April and drove 10 miles and the P0420 and P0111 code came back once again. I'm not to worried about the P0420. However, Could it be that I have a bad wiring harness causing the P0111? Is there something wrong with my PCM? Or, Could it that the midpipe is causing the issue? NOTE: I do have a Cobb AP that is ready to be installed to the car. But I'm waiting to see if a solution can be found before the install. I know that the Cobb can prevent certain CELs. Is the P0111 one of these CELs that should be masked?
I've been getting good gas mileage and the car seems to be running alright. Bottom line; will the P0111 cause any long term damage to the motor? And what do you guy think is a the fix for this combo of problems?
I'm sorry for all the questions that are asked in just this one post... But any help that you guys can bring to the table would be appreciated. Thanks In Advance
Old Jun 2, 2009 | 08:02 PM
The IAT sensor is bad or the wring is bad. Its under and near the intake.
Old Jun 3, 2009 | 06:20 AM
Pico's Avatar
It's Complicated
I was thinking the IAT was bad the first two times it was replaced. But now I'm thinking something else could be the problem like the wiring harness. Isn't the IAT located inside the MAF sensor? I'm pretty sure its all one unit.
Old Jun 3, 2009 | 06:11 PM
shadycrew31's Avatar
WENTGERMAN
they are generally in different places. lets consult the manual nope same sensor...
OK so there are 3 possibilities I can come up with
1) PCM is fubar
2) there is corrosion on the connector to the MAF/IAT or the ECT sensor
3) there is corrosion on the PCM harness or a bent prong
you can check for continuity if you think its the harness use pin D on the maf harness (consult the manual) put the positive on pin D and the negative on a ground wire if there is continuity your golden.
also you can check your ECT sensor it may be faulty sending messed up temp readings its located on page 288 in the #3 manual engine details.
Please look past the grammatical errors I'm dropping a deuce.
Old Jun 4, 2009 | 10:20 AM
Pico's Avatar
It's Complicated
^^^ i do appreciate your helping out while taking care of business LOL. i will take a look for any type of corrosion. the car being a year old i think the possibility of corrosion will be slim. but i will check. I will look for a bent prong too and continuity. Where can i find the ECT sensor? i will have to get my hands on a 8 manual.
I'm going put my Cat and stock airbox back on this week reset the PCM and see if the problem continues. If so, its going to the dealer.
spelling errors are acceptable while on the pot. Haha
will this problem cause any type of motor issues now or in the future?
Old Jun 4, 2009 | 11:20 AM
WENTGERMAN
When I had this problem on my celica I noticed 0 problems and I ran with that on for 4 years. However that is a celica..
In all honesty the only sensors you need are o2, maf, coolant, and the fuel gauge. all the other bs is more for safety reasons. For example if the IAT were reading the same temps as the ECT that would be a safety issue...
That's why when you switch to a stand alone like haltech you wont see all the bs sensor's just the ones that keep the a/f in check and make the powwaaaaa...
To summarize if the car still runs performs and gets the same MPG I wouldn't go replacing a whole engine harness over it. However if its an easy fix like a bent pin or some corrosion id handle it.
P.S. If its your PCM this could be the calm before the storm and I'd get that replaced asap.
P.P.S. If you search on the forums there is a link to a website that hosts the entire service manual in PDF form
Old Jun 4, 2009 | 12:32 PM
Pico's Avatar
It's Complicated
I found the link for the manual. there's a few sections that wont let me download 4,10,11. i think two of these sections could help me with my problem. I'm hoping for an easy fix. However its an 08, bought it less then a year ago. I've never played with anything under the hood so I'm thinking its a harness problem or PCM problem. Like i said in my first post all these issues started after my mid pipe install- have the racing beat intake for over 5,000 prior the mid pipe and the CELs.
I'm going try to take a look asap- as soon as the rain stops. But i/m very curious to see what will happen once i put in back to stock.
Old Jun 4, 2009 | 12:58 PM
WENTGERMAN
try the stock mid pipe back on with the airbox...
The p0111 getting thrown because of a mid pipe is slightly confusing but hey ya never know these cars have a mind of their own.
you need section 3 that gives you the pinouts. in the search field on the PDF document type MAF Sensor and it will pull it up, then type ECT Sensor and if you keep paging through it will show you where its located and how to replace it, you can also type IAT sensor they come off the maf harness but the pinouts are different on the PCM.
Old Jun 4, 2009 | 01:02 PM
Pico's Avatar
It's Complicated
Thanks shady... your info will help a lot.
Old Jun 4, 2009 | 01:03 PM
WENTGERMAN
I hope so.. Goodluck and godspeed!
Old Nov 19, 2012 | 07:03 PM
EricB's Avatar
#225 of 1000
so is it any coincidence that my 40th anniversary is also throwing a P0111?
All sorts of problems after i went off a shitty driveway that had a 1/2inch gap between the driveway and the road.
my TCS light came on (squiggly lines) but not the DSC, or ABS or anything. Only the TCS went on and stayed on for my whole commute.
then while at a red light i checked my fault codes just for poops and giggles and i noticed the P0111, with the P0111 its not throwing a cel.
I searched it with torque on my phone. Im obviously getting a P0420 from my RB midpipe... but i cleared that the day before.
Old Dec 25, 2012 | 07:53 PM
Darkning's Avatar
Make that 3 40th Anni drivers with a P0111. No way it's related to this specific model but interesting coincidence nonetheless.
Beyond intriguing is that I get it only when I'm down near my in-laws which is a 2 hour drive from Charlotte. It popped up at Thanksgiving and it's popped up again as soon as I got here on Christmas Eve. It can't be the distance because I took a 3 hour drive to Road Atlanta and didn't have any issues.
Probably unrelated - but the car was throwing random misfire codes after cranking the car once I got here. Swapped out all my coils with BHR stuff before Thanksgiving and the plugs were new(but involved in a deflood at time of installation with the coils). Drove perfectly fine all the way down and perfectly fine again once the car runs a couple mins, but the start up this morning and last night were awful and the idle was going nuts... reset the ECU via brake stomp and that seemed to chill out, but the P0111 is still hovering - although as Eric said, no CEL.
Old Mar 8, 2013 | 10:39 PM
EricB's Avatar
#225 of 1000
my p0111 is getting worse...
i recently turned the option to notify me verbally from Torque of any error codes...
When i first got my P0111 i noticed it in the middle of my commute in the morning.. Then it was always around the middle of my commute..
then more recently it was when i was driving home at night
more recently today, 30seconds - 2 min go by after i start the car and it throws the P0111, then when i start the car at night and its warming up and i start driving it gives me the P0111 again, then while almost home it gave me the code again... thats 3 times in 1 day.
I would take it to the dealer to have them figure it out, but im lowered and i have a midpipe.. i dont want them knowing about any aftermarket stuff incase i need a reman in the future... im unsure if a midpipe would cause any warranty concerns.
Old Mar 9, 2013 | 11:07 AM
j9fd3s's Avatar
the FSM says "• The PCM compares the IAT with the ECT when the engine is running. If the IAT is higher than the ECT by 40 °C {104 °F}, the PCM determines that there is an IAT sensor circuit range/performance problem."
so basically if coolant temp is 195F and intake air temps are 299F or more, the ecu throws a code...
so i think the next step would be to look at the IAT in the scanner/phone/dongle/etc, it should read something sensible, and 300F is way wrong
if the AFM is new/replaced, this kind of narrows it down to the wiring harness/afm connector/pcm.
Old Mar 23, 2013 | 11:42 PM
EricB's Avatar
#225 of 1000
sorry for the late reply... i didnt notice that you responded.
My coolant has been anywhere from 70- 195F and my intake air temp has been around the ambient temp.. 30-50ish
This problem only started happening when it got cold outside.
The computer uses the readings from the MAF for IAT correct? so would cleaning it with MAF cleaner do anything? The readouts im getting from torque are never crazy and always around ambient temp.
Old Mar 24, 2013 | 11:07 AM
j9fd3s's Avatar
yeah cleaning the MAF would work, i think the IAT is the other wire/sensor element.
if the AIT is normal, then the light should be off, although keep watching it, if it does something bonkers, then that might be where the code is coming from
Old Mar 24, 2013 | 01:09 PM
EricB's Avatar
#225 of 1000
i did a quick search and didnt find much relating to the IAT, where is the IAT wire?
The IAT has a light?
Also ive never seen the temps read out anything crazy while watching torque.
Old Apr 22, 2013 | 05:39 PM
Darkning's Avatar
My scenario is pretty much the same as Eric's. I watch my intake temps and coolant temps in torque and neither is ever out of place. Intake is usually around 10 degrees higher than ambient if there's airflow. And coolant is never really over 195 when the code has blipped.
Note that I never get a CEL with it but Torque does announce it.
Old Apr 22, 2013 | 07:56 PM
EricB's Avatar
#225 of 1000
exactly the same thing.. exactly.
i should note thats its gotten a bit warmer out and i stopped getting the P0111, i expect it to come back randomly though.
xAgyex
Jun 3, 2026 03:47 PM
HMSS013
Series I Do It Yourself Forum
Apr 9, 2023 09:13 AM
Mar 1, 2019 09:00 AM
LiveWire
General Automotive
Nov 16, 2015 11:41 PM
yapakanichi
16
Jul 28, 2015 03:44 PM
