ap with cobb stage 1
Old May 23, 2009 | 04:36 PM
luis_o_98's Avatar
my ap stage 1 map from cobb doesn't seem to want to work to well. all i have on the car right now is the mazsport ignition kit and a ground kit(which shouldn't do anything as far as tunes i think).
whats is everyones thoughts on this
Old May 23, 2009 | 06:40 PM
chickenwafer's Avatar
Nope
What do you mean "doesn't work well"? That can be many different things.
if the problem is at higher rpm, then it's your MazSport ignition more than likely
Old May 24, 2009 | 02:46 AM
Flashwing's Avatar
3-wheeler
Luis you probably should check out the various COBB threads as there's a lot of documentation showing the COBB stage 1 tune doesn't work well for any RX8. Most people report lean conditions.
Mazsport's ignition kit also requires some dwell adjustments which, without them, may contribute to some issues.
Your best bet is to get the car a custom tune as that's the only way you're going to see any benefits from the accessPORT.
Sheldon24
Sep 19, 2015 02:37 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
BigBadChris
Sep 7, 2015 01:49 PM
