need new clutch (not really, just want one)
Old May 18, 2009 | 06:17 PM
leemoshuffle's Avatar
TX need new clutch (not really, just want one)
Getting a new clutch soon, I just wanted to hear some recomendations, war stories, or just what info you people have. Any info is always good info.
My application will be daily driver + track days + autocross (BSP scca).
I have always leaned towards ACT in the past. I am interested in trying somthing new. Like I said, any info is good info.
Lee
Old May 18, 2009 | 06:20 PM
laythor's Avatar
I zoom therefore I am.
I would suggest sending a PM to Charles R Hill. He'll not only answer all your questions but his company , BHR, can sell you all the parts you need.
Old May 20, 2009 | 07:56 PM
Well guys, thanks for the info.
I am going to try an exedy stage one per your recomendations.
It is nice to see that there are peoiple with usefull info in car forums again.
Old May 20, 2009 | 08:02 PM
deadphoenix52's Avatar
meh.
talk to BHR. they will take care of you. im very satisfied with my clutch/flywheel combo
Old May 21, 2009 | 10:04 AM
Cattywampus's Avatar
Turbos blow!!
Hey Ray, what is the difference between thick and thin pressure plate disks? Do the thin plates dissipate more heat?
Old May 22, 2009 | 04:22 AM
wow,
killer info.
to leemoshuffle
i have a exedy stage one clutch. that has less than 10% wear on it. comes with a brand new bhr throw out bearing. long story.
you win.
send me a pm.
Old May 25, 2009 | 08:21 PM
Wow, thank you for all the info.
It is much appreciated.
I may have not mentioned that I can hear thepilot bearing is beginning to
tear itself apart.
I know the stock clutch is pleanty strong for the app. However, later when i decide which
power adders to use. Or maybe a 20B. I will need a stronger clutch.
Again, Thank you so much for the info.
Lee
Old May 27, 2009 | 01:40 AM
Winning 8's Avatar
Hot Pit
the 92-95 RX7 have a problem with the act heavy duty pressure plate, they will bent the fork or wear the pivot ball. I don't know if the RX8 did the upgrade on those parts yet.
you should get the flywheel at the same time while you do the clutch.
Old Mar 21, 2010 | 09:24 AM
LudoMQ's Avatar
Charles, would it be safe to assume you recommend the ACT SS Street Disc? My car is stock for the moment but will eventually have a few power upgrades. I'm looking to replace the clutch and pilot bearing as soon as possible and just need a lil advice as to what to get. Thanks.
Ludo
Old Mar 24, 2010 | 10:56 AM
otakurx's Avatar
Rotorheaded Geek
I've been running the CenterForce Stage 2 clutch for about 30k miles now and absolutely love it. The pedal feel is about the same as stock but the engagement is much better. I really like it so far, it's a very snappy clutch which throws some that have driven the car off since it doesn't feel like it's going to be.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
