Grounding kit DIY
Old Dec 26, 2003 | 05:00 PM
Dick Carlson's Avatar
SpellingNazi
Grounding kit DIY
Per this thread (https://www.rx8club.com/showthread.p...threadid=14728)
I built and installed a grounding kit, but I would change two dimensions. Terminal B1 and A3 should both have an 8mm hole rather than 6mm per the others. I would then attach B1 to the accessory terminal on the battery negative cable, rather than use the clamp bolt. A3 I have attached to a grounding bolt on the aluminum portion of the intake manifold which appears to be the same as the Japanese instructions.
Old Dec 26, 2003 | 10:51 PM
RX-8 friend's Avatar
Yes, good plan. When we put the Mazda one on Canzoomers car we filed out the hole on the battery -ve terminal to fit on the stud. The Mazda kit fit on the lower intake manifold grounding bolt without modification.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
