West RX-8 Forum Serving CA, NV, AZ, HI
something wrong in my car
Old May 7, 2009 | 03:30 PM
jay_ar1010's Avatar
my car just keep died in the freeway and i dont know what's the problom...i just change my spark plugs,oil change....but just the engine is kinda not in a good sound ..its like something wrong....but i dont want to touch my engine right now....coz i might spend money again...and im going home for vacation... and i need money right now...maybe i'll try to tune my car when i go back....hepl guys....
Old May 7, 2009 | 04:02 PM
philipchan's Avatar
The warranty should cover, bring it to the dealership!
Old May 7, 2009 | 11:41 PM
Plugs could be loose or the wires. Check the wires.
How old is the battery?
Did you disconnect the battery when you serviced?
List year and miles
Old May 8, 2009 | 12:18 AM
Franky A's Avatar
Rotary User
Sounds like it's a battery problem. How old is the car?
Old May 8, 2009 | 07:06 AM
scremn8's Avatar
the more things change
my spark plug wires came loose on the fwy once.
went dead just as i was changing fwy's..
check wires then battery, then tow to dealer.
if it goes to dealer make sure you have it on
a flat bed tow truck...
Old May 8, 2009 | 10:50 AM
Atilla's Avatar
I am THAT guy
The sound coming from your engine - is it a knocking sound??
Old May 8, 2009 | 11:49 AM
bao0518's Avatar
if you have a after market intake, check that. If there is no air or not enough air going into the engine..it will turn off
Old May 8, 2009 | 11:52 AM
check out the West Coast peeps coming to the rescue!
some great suggestions here.
- Has your car been driving fine prior to this?
- Definitely check your battery cables
- The spark plug cables have been known to come loose.
- If you disconnected the battery cable, could be the all the fuel trims were reset so the car is trying to settle them. (this can lead to a rough idle for a few drive cycles)
- Did you double check the MAF sensor connection?
- How long since you cleaned the MAF?
- Aftermarket intake?
One last suggestion: double check to make sure the coils are going to the appropriate plugs. I know this sounds stupid but sometimes the simplest thing is what causes the issue.
Old May 8, 2009 | 11:53 AM
Atilla's Avatar
I am THAT guy
Bao puts up a good point - If the maf is loose or not secured, the motor will shut off. This happened to me once when i replaced my intake box. Scared the **** outta me...
Old May 8, 2009 | 08:40 PM
Maybe it morphing into a Camary.......
Old May 12, 2009 | 01:45 AM
Spinning Sushi's Avatar
I <3 Sushi
Camry's (Camries?) are awesome!
Old May 12, 2009 | 08:10 AM
jay_ar1010's Avatar
engine light on now.....i fill like there's really something going on my car...
Old Jun 4, 2009 | 03:21 PM
remixlp's Avatar
Get a compression check. I have the same issue right now and about 4 error codes. I cant figure it out.
Old Jun 4, 2009 | 05:28 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
were there any popping sound coming from speakers when the car was dying out?
Skyl3r
Dec 2, 2019 04:51 PM
michaelsk8er
Nov 9, 2015 07:06 AM
Redheddude222
Sep 13, 2015 12:57 PM
marc2820
Jul 26, 2015 10:47 PM
Kangarhew
Jul 18, 2015 08:27 PM
