car has power and is turning over strong...but wont start
Old May 5, 2009 | 06:21 PM
vglnte1's Avatar
almost like the fuel pump is out?
any ideas?
Old May 5, 2009 | 06:32 PM
invasion08's Avatar
Going to need more info about the car: Year, Mileage, and anything else that will help us help you
Old May 5, 2009 | 08:18 PM
vglnte1's Avatar
2005 6 speed. about 30k miles
no mods
Old May 5, 2009 | 08:20 PM
Jon316G's Avatar
Grasshopper
Engine Flooded?
Old May 5, 2009 | 08:23 PM
vglnte1's Avatar
i found this....true?>
http://www.fixya.com/cars/t1422869-m...wont_start_ran
Old May 5, 2009 | 08:24 PM
vglnte1's Avatar
Originally Posted by Jon316G
Engine Flooded?
i never pumped the gas pedal, and as soon as i started to crank it it did this...i know nothing of rotary motors....i have only worked on GM V8's.
Old May 5, 2009 | 08:28 PM
Jon316G's Avatar
Grasshopper
You don't pump the pedal, you hold it down while starting.
This keeps it from injecting more fuel into the chambers.
Don't do it for more than 10 seconds.
Some have had better luck removing the spark plugs and then starting it with the gas pedal held down (with a rag nearby to catch the fluids).
There are other methods to help "de-flood" so you might want to search for that if this doesn't turn it over.
Old May 5, 2009 | 08:44 PM
vglnte1's Avatar
lost my book for the car
can someone post a pic of which one the ful pump fuse is?
Old May 5, 2009 | 08:52 PM
Jon316G's Avatar
Grasshopper
You do know that the panel cover has the layout
Old May 5, 2009 | 08:53 PM
Jon316G's Avatar
Grasshopper
You can also download the owner's manual from MazdaUSA
Old May 5, 2009 | 09:37 PM
04RX8man's Avatar
Rotary Powered Countryboy
use the search function!!!!! remove plugs....take fuel pump fuse out....crank car 10 sec at a time till no fluid comes out then install plugs and fuse then it should fire up...
Old May 5, 2009 | 09:54 PM
vglnte1's Avatar
i removed the plugs....well the 2 i could get to....and there was no fluid in there....
so im supposed to try to start with no fuse or plug? what will that accomplish?
Old May 5, 2009 | 10:40 PM
Alexb's Avatar
desperately needs a drop
Isn't it possible the plugs are just dead altogether?
Old May 5, 2009 | 11:27 PM
vglnte1's Avatar
no idea. i did the fuel fuse trick. i removed all 4 and did the whole service buliten and nothing....**** this car
Old May 6, 2009 | 12:03 PM
Please update your profile so we know where you live.
Your local club members should be able to help you out.
Are you getting any spark at all?
Have you ever changed the plugs?
Its time for a tune up at 30k per manual, so don't say **** the car when you don't follow maintence guide lines.
We are here to help.
Edit: So your first post says you bought a 2006 now you say its a 2005. So what is it? Post a picture of your car.
Here's a link to a shop manual for future reference.
http://foxed.ca/rx7manual/2003mazdarx8/
Old May 6, 2009 | 12:35 PM
Huey52's Avatar
Registered Zoom Zoomer
We understand your frustration. Any car can be flooded, but the rotary is a bit more susceptable.
Taking out the plugs and removing the fuel pump fuse allows you to crank the engine, to drive out excess fuel/vapor, without introducing more fuel which would be self-defeating.
Once you're assured you're 'dry', reinstall the plugs and fuse and attempt start.
Alternatively, if you have a manual transmission, you can have someone push/pull you with ignition on and drop it into gear to start.
btw: if you have an '05 built before circa January '05 you may need the upgraded starter and battery (if you have a Panasonic battery you probably have the older starter; if an Interstate probably the newer).
Old May 6, 2009 | 12:59 PM
White_Shadows's Avatar
Question of the century. How do you start your car every time you go to drive it? Do you just start and go? Or do you warm it up every single time you start it? If not, enjoy the flood and there are alot of stickes and tips and tricks. When all else fails call for a tow to local shop. Don't hate the car just for not understanding it. A bit more to it then an old 350.
Oh and do you drive it like you stole it? If not compression check time. No worries though you are still under warranty, but read read read. This is not a push button and go car.
Old May 6, 2009 | 02:40 PM
Nubo's Avatar
Lubricious
Let's not muddy the water with misinformation. Start and go is perfectly fine unless extremely cold weather.
Better to get back to basics. Spark, Fuel, Air, Compression. Same as any other car.
Jesus Martinez
44
May 6, 2025 08:09 AM
delicious_dallan
Jan 17, 2020 09:17 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
