CEL P0037 After RP cat install
Old Apr 24, 2009 | 03:31 PM
renaldo's Avatar
Hi,
My stock cat failed a few weeks ago (p0420) so instead of replacing it with stock I got the RP High flow cat. I got that installed about 2 weeks ago and this morning I started my car and the CEL came on with P0037.
I researched this and it sounds like it is the rear o2 sensor? Any advice on this? Could this have been the problem all along or are the codes unrelated?
Old Apr 24, 2009 | 03:34 PM
Re-set the ECU
Old Apr 24, 2009 | 03:37 PM
renaldo's Avatar
Originally Posted by Razz1
Re-set the ECU
I cleared the code with an OBD2 reader and it came back after 2nd start. Clearing the ECU different?
Old Apr 24, 2009 | 03:38 PM
is the rear O2 sensor hooked up properly? wires on it are undamaged?
You "shouldn't" have a CEL from the supercat. What did your stock Cat look like when you took it off?
Old Apr 24, 2009 | 03:39 PM
https://www.rx8club.com/series-i-tech-garage-22/new-code-after-mid-pipe-installed-fix-171292/
Sensor could have been broken during install.
Old Apr 24, 2009 | 03:54 PM
renaldo's Avatar
We were very careful taking it off. I doubt that we damaged it. I guess it could just be a coincidence.
Old Apr 24, 2009 | 04:10 PM
Make sure the exhaust doesn't have a leak.
No leaks, then for the fun of it clean the MAF, re-set ECU and see what happens.
Old Apr 24, 2009 | 06:26 PM
teknics's Avatar
Certified Mazda Tech
those sensors are fairly sensitive so "damaging" it doesnt require too much
kevin.
Kanthinar
Dec 21, 2015 01:24 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
RenzoRx-8
Aug 25, 2015 10:29 PM
dbarber
Jul 25, 2015 01:34 PM
