Steering Stiffness and Pull
Old Apr 23, 2009 | 01:59 PM
hdready's Avatar
I own an 04 Auto RX-8 and I'm gettin stiffness in my steering and when I slow down 55 below my steeringwheel wants too literally pull. Any ideas on what this could be? Want an idea before i take it in!
Old Apr 23, 2009 | 02:02 PM
StealthTL's Avatar
Steering is electric - search for threads with 'steering' in the subject.
https://www.rx8club.com/series-i-tech-garage-22/steering-breaks-78508/
S
Old Apr 23, 2009 | 02:04 PM
dozer's Avatar
on his 3rd rx8
stealth, help the newbie out a lil
does your power steering light come on?
Old Apr 23, 2009 | 02:07 PM
jmc23200's Avatar
Get an alignment and make sure your tires are properly balanced. Also, take a look at the tires wear. If it is uneven, at low speeds it may be causing it to "push" the car in a direction.
Old Apr 23, 2009 | 02:18 PM
dozer's Avatar
on his 3rd rx8
well if there some kinda hard pull (ive experienced it) i think you got condensation in your PS connector, thus resulting in the little metal prongs getting corroded, thus resulting in a faulty connection
solution - get under your hood, remove the airbox and the plate that holds it underneath it...you will see the connector right under it, and right above the radiator...pull it apart and use some electronic cleaner (you know that stuff to dust off keyboards and sh*t) spray some on the metal prongs and dab some antisieze on em...plug back together and put everything back...you should be fine
Old Apr 23, 2009 | 02:21 PM
hdready's Avatar
I have had tire alignment it didnt help. No power steering light either.
Old Apr 23, 2009 | 02:22 PM
dozer's Avatar
on his 3rd rx8
^i think its about to go the route i talked about...mine did the EXACT same thing...just try cleanin it out a lil
Old Apr 24, 2009 | 04:43 PM
Nubo's Avatar
Lubricious
Or, if you are familiar with splicing wires, you can cut the connector out altogether, and solder the wires directly. If the problem was the connector, this will fix it permanently. Cleaning reseating and tweaking was only a temporary fix for me.
Old Apr 27, 2009 | 09:09 AM
jmc23200's Avatar
When in doubt, solder, super glue and duck tape is all you need.
theblinkof
Oct 4, 2023 05:24 PM
200.mph
Dec 10, 2018 03:49 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
Tsurugi
Sep 7, 2015 08:27 PM
