ABS and TCS Light
Old Apr 17, 2009 | 02:21 PM
jdzoom8's Avatar
ABS and TCS Light
This morning when I started my car the ABS and TCS light came on after a few seconds and stayed on (1st time this has happened). After my car warmed up, I shut it off and restarted with my foot on the brake. Upon the restart the light cleared although after about 3 seconds I felt the ABS in the brake pedal pulsate and heard an electronic noise, then the ABS and TCS light came on. I shut the car off and restarted again, this time without my foot on the brake. The ABS And TCS light stayed off until I pressed the brake, no pulsation this time.
I wanted to check my fuses and the ABS sensor. Which fuses may cause this (I searched and found the STOP fuse), any others?
Where is the ABS sensor located? Pictures would be nice.
What else do I need to check? Anyone else with this experience?
Thanks.
Old Apr 19, 2009 | 12:20 PM
mikko79's Avatar
Hi!
I have the exat same problem. The Bosch diagnostic gives errorcode C1290 _faulty brake pressure sensor_ or something like that.
I tested the sensor with electric meter but it has no shorting or other problem. The problem is in some abs-sensor in one of the wheel hubs. I noticet that the is some short-circuit because it also burns the brake light fuse.
Sorry for my bad english...
Old Apr 19, 2009 | 06:18 PM
If you get a power loss like a battery disconnect these lights will come on.
For the fun of it... turn the wheel all the way to the left and all the way to the right when the car is idling.
They may go off.
Old Sep 25, 2009 | 05:22 PM
gtommy's Avatar
did you manage to fix this problem?
I have the same problem and the tech pulled out code C1290 : Pressure Transducer Circuit.
I was exepecting some ABS Sensor to be either dirty or damaged.
Old Sep 25, 2009 | 06:29 PM
Macius8's Avatar
Had a similar problem, tested out my left wheel hub and it had no v/signal going to it. Bought a new one, when replacing I noticed some ABS sensor wires were cut, probably due to some road debris. Soldered the wires and everything looks good.
First off check if there is no visible damage on both front wheels. Then check the signal at each wheel hub and the wire connectors that lead to the sensors. If your left one does not work remember I have a spare one and will sell it you cheap
Old Oct 3, 2009 | 02:11 PM
gtommy's Avatar
Thats sounds like my problem. I'm pretty sure it happened after driving on a bottle of glass while parking. It made a nasty noise, so Im pretty sure I cut something there.
It's probably the right front wheel.
So you bought a sensor but you ended up soldering the wire without installing the new sensor?
I'm wondering if I need a new sensor or if I can solder mine...
Thanks for the info!
Old Dec 26, 2009 | 11:22 AM
shinka911's Avatar
I have the same problem, but all my wires are intact and making good connection. where would i get someone to pull that code?
Old Dec 26, 2009 | 11:39 AM
SRrx-8JC's Avatar
Felix "The Man" Wankel
OK I have the same problem, but mine does not make noises or anything and it only comes when I turn my headlights on......
Any ideas.....
Old Feb 10, 2011 | 06:39 PM
Bail-Dawg's Avatar
Im having the same issue
pulling code c1290
Just wondering how you ended up resolving this issue
RX-8 Racing
20
May 14, 2016 06:25 PM
xAgyex
Sep 28, 2015 08:54 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
