Eibach Springs - Pro Kit
Old Apr 16, 2009 | 10:04 PM
millchan's Avatar
Question Eibach Springs - Pro Kit
just like the title, yesterday I got the new spring on my 8...but...
The rear is lowered as expected
The FRONT is "RAISED" even higher than stock...
Help...did someone experienced it the same way?
and how to make it right...
Old Apr 17, 2009 | 02:30 AM
Juice's Avatar
I made some poos
Turn your wheels all the way to the left. Loosen the upper a-arm bolts that you can reach. There are 2 on each side (17mm). Once you loosen the 2 bolts you can reach, turn your wheels to the right and loosen the other 2 bolts. DO NOT REMOVE THE BOLTS. Just loosen them a little to take the tension off the bushings. Drive the car forward at least a few feet and drive it back a few feet. Do that a couple of times, then push the front of the car up and down a few times.
Tighten the bolts back up and the car should be significantly lower. Search the site for preloading for more info.
Old Apr 17, 2009 | 03:35 AM
good job!
https://www.rx8club.com/canada-forum-35/eibach-springs-pro-kit-171725/
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
duworm
Oct 1, 2015 04:57 PM
Digitz0070
Sep 27, 2015 07:49 AM
