Need help/tip with putting rear link back on
Old Apr 15, 2009 | 01:35 AM
JustinD's Avatar
While attempting to install Autoexe rear memberbrace, I unscrewed the bolt holding the rear link.
This is the rear link that's out. (sprayed yellow)
http://www.swankmonkey.com/mig/albums/tein/IMGP1561.JPG
I can't seem to align it properly to screw it back on. Will this require undoing the whole rear suspension?
Any advice will be greatly appreciated.
Old Apr 15, 2009 | 02:19 AM
Spinning Sushi's Avatar
I <3 Sushi
Unbolt the shock to give it some slack, under the brake rotors should be a pivot point for another arm. Carefully put a jack underneath it and jack it up, this will help you realign the rear link that's out. After that, just put back on the shock and you're done.
Old Apr 15, 2009 | 02:26 AM
JustinD's Avatar
Thanks for the reply. I've actually posted the wrong pic..
I meant to post this.
https://www.rx8club.com/attachment.p...7&d=1115734807
This is the one that goes from under the brake. Should I still go with undoing the shock bottom to realign it?
Old Apr 15, 2009 | 05:38 AM
DOMINION's Avatar
I don't buy Kool-Aid
See attachment
Attached Thumbnails Need help/tip with putting rear link back on-4-3.jpg
Audio Concepts ATL
Sep 26, 2021 01:59 PM
tbiggybig
Aug 13, 2016 06:30 PM
akagc
Aug 11, 2015 07:07 PM
CMRine04
Jul 27, 2015 09:46 PM
