The Engine Oil Journey... from filler entrance to oil pan
Old Apr 14, 2009 | 01:27 AM
delhi's Avatar
Grand Chancellor
I am wondering the travel path of the engine oil when it is poured into the filler hole at the top. Where does it meander to first?
Engine injectors? oil cooler? oil filter? the pan has to be the last right?
Old Apr 14, 2009 | 02:40 AM
ASH8's Avatar
Super Moderator
From the Filler to the Sump Pan..
From Sump through Sump Oil Strainer to OIL Pump...
From Oil Pump to OIL Coolers...
From Oil Coolers to Oil Filter..
From Oil Filter to MOP (Metering Oil Pump) and Eccentric Shaft.
Through Centre of Rotors and back down to the SUMP again...
The Cycle starts again...
Old Apr 14, 2009 | 12:05 PM
delhi's Avatar
Grand Chancellor
great! thanks!
Old Apr 15, 2009 | 10:33 AM
RotaryResurrection's Avatar
kevin@rotaryresurrection
When oil is poured into the filler hole, it drains straight down through the intermediate iron and into the oil pan. Right by the dipstick. Simple as that.
When the engine is in operation, it follows the general outline posted above.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Skyl3r
Dec 2, 2019 04:51 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
RotaryRider
Jul 20, 2015 07:05 AM
