Oil Drain Plug Gasket
Old Apr 12, 2009 | 06:28 PM
mryoshi's Avatar
Pyscho Dad
OK I am chaing my oil today. Went and bought KN filter and Royal purple oil.
I asked for the drain plug gasket and was told they have one that is exact same spec... They said it was just a 14mm gasket so they gave me a 14mm copper drain plug gasket.
Upon removing the one on the car I see that it is not copper but silver colored.
The copper one is slightly larger outer diameter. about 1.5 mm larger OD, the ID is the same. Will this work without causing a problem?
Unfortuneatly my car is sitting without oil or a drain plug at the moment... so have to get it right before can drive car.... grrrr
Old Apr 12, 2009 | 06:35 PM
invasion08's Avatar
It should be fine. Do not worry about the color of the gasket since they are different metals. Ones copper and the other steel. I do not think the OD will affect or hit anything so put it on. Just check for leaks when you start the car. But you will be fine do not worry.
Old Apr 12, 2009 | 06:50 PM
mryoshi's Avatar
Pyscho Dad
cool! thanks.
Cleaned area with parts cleane after installing and sprayed a little bit of magaflux on, so if there is a leak it will pop up like a sore thumb.
I was more worried about possible difference in torque specs between copper and steel washer.
Cheers,
yoshi
Old Apr 12, 2009 | 06:57 PM
invasion08's Avatar
You will know when it is tight. do not over tighten it.
Old Apr 12, 2009 | 07:11 PM
invasion08's Avatar
How did it go
Old Apr 12, 2009 | 07:12 PM
mryoshi's Avatar
Pyscho Dad
I used spec of 27ft/lbs. I saw that range was 25.4-28... so went in the middle.
If I cant find a torque spec I wont do it. Have seen way too many probs resulting from improperly torqued stuff.
I was pretty confident it would be fine with copper washer just wanted to hear another oppinion. While I have a lot of motorcycle wrenching experience/training, car stuff is only what I have done on my own cars.
Can say they put that filter in a spot that is a pain in the *** to get to..... I dont have little dainty hands and arms....
Everythgin went just fine BTW
Old Apr 12, 2009 | 07:17 PM
invasion08's Avatar
Thats good. I replaced my drain plug with this
it works great
http://www.quickoildrainvalve.com/
Old Apr 13, 2009 | 01:10 AM
Lebren's Avatar
RX8club group buy vendor
it works great
cool! Oil speedbleeds can save a bunch of time. I, however love hot oil dripping all the way down to my elbow after dropping the plug into guess where? Yup, the oil drain pan I think it's time to invest in one of these.
Old Apr 13, 2009 | 01:16 AM
HWK11's Avatar
Lighting Yellow
^thats pretty nice, but which one did you get?
Old Apr 13, 2009 | 01:18 AM
DOMINION's Avatar
I don't buy Kool-Aid
Sweet! I want one
Old Apr 13, 2009 | 04:06 PM
invasion08's Avatar
It makes changing your oil so much easier. Send them and email or call them and they will tell you what you need.
Old Apr 13, 2009 | 04:32 PM
StealthTL's Avatar
The Fumoto valve is nice, but for our car it needs a 25mm extension, which makes the whole thing stick out a bit.
It's not an offroad vehicle, so should be ok.....
Copper colored copper gaskets are best, otherwise they might not be soft enough....the silver one is prolly aluminum, and therefore not as soft/compliant/pliable.
Old Apr 13, 2009 | 05:10 PM
Nubo's Avatar
Lubricious
^+1 Copper is nicely malleable, so it makes a great compression washer for this.
The nicest ones I've used were on old VW bugs. Thin malleable copper wrapped around some type of fiber core. They squished real nice.
On this car, I got a fumoto valve right away. 5 years and counting.
Old Apr 13, 2009 | 05:12 PM
Socket7's Avatar
ಠ_ಠ
I have plastic crush washers for my oil drain plug. They work great.
drebbrnator
Dec 27, 2018 07:02 PM
RicerX1
Jan 11, 2016 05:59 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
eazzyg
Aug 12, 2015 09:09 PM
