Need some rotor specs for the base model RX8 (front rotor)
Old Apr 6, 2009 | 09:57 AM
Deals Gap Rotary Rally's Avatar
DGRR 2011, 4/28-5/1/2011
I'm trying to retro fit RX8 brake system into an another Rotary and wanted to see if someone will do me a favor and spec their base model (16inch wheel) front rotors for me..
I need the following info as accurate as possible..
A. Rotor Diameter (mm preferred)
B. Rotor Thickness (mm preferred)
C. Rotor Offset (mm preferred)
Phil
Attached Thumbnails Need some rotor specs for the base model RX8 (front rotor)-centricstandard.jpg
Old Apr 7, 2009 | 09:52 AM
Bump!
Old Apr 7, 2009 | 10:03 AM
bse50's Avatar
#50
http://www.racingbrake.com/RX8_NON_S...1-211-1446.htm
I coulnd't find the hat thickness though.
Old Apr 7, 2009 | 10:27 AM
Thanks! I just called Power Slot and got the diameter and the thickness.. They also gave me 303mm OD and 24mm thick.
They also didn't know the hat thickness.. Anyone can confirm if its the same as the 6sp MT GT hat thickness or not??
Old Apr 7, 2009 | 10:33 AM
Easy_E1's Avatar
What do you want measured exactly?
Rotor offset?
I have one in the garage.
Old Apr 7, 2009 | 10:48 AM
I just got off the phone with Warren at Racing Brake and he told me that the hat thickness of Sport and Non Sports are the same..
Thanks guys for your help!
Old Apr 7, 2009 | 10:49 AM
Rotor offset?
If you could measure the hat thickness.. From where the wheel mounts to to the surface of the rotor.
If you could measure that so I could confirm what Racing brake told me, that would be great!
Panthersn
Jul 13, 2021 06:30 AM
vapor2
Oct 8, 2015 02:08 PM
MolecularConcept
Aug 5, 2015 04:43 PM
CA441914
Aug 5, 2015 11:33 AM
robd1337
Jul 31, 2015 09:35 PM
