Mazmart thermostat and Interceptor-X: would this cause engine to run richer?
Old Apr 2, 2009 | 08:12 AM
Luckycat's Avatar
Hello,
I plan on installing Esmeril Kit on my car. I also plan to install Mazmart water pump and thermostat at the same time. Now the new thermostat open sooner than the stock thermostat and would likely result in cooler coolant temp. Would this cause the engine to run richer because the PCM senses colder coolant temp? How would this affect the AFR in general? I live in a cooler climate up in MN (cold winter, cool weather 6 or so months out of the year and 80-95F summer. Car not driven in winter) and wonder if it necessary to need this thermostat at all. I plan to use stock radiator and mazmart pump for sure. My goal is to make sure the car has the additional cooling capacity that it needs with the turbo. Car will never see track and it would be driven spiritly from time to time.
Ronn
Old Apr 3, 2009 | 09:12 AM
Luckycat's Avatar
Anyone??????
Noone has install this new thermostat to a turbo equiped 8????
Old Apr 3, 2009 | 09:25 AM
Easy_E1's Avatar
You will be fine.
Old Apr 3, 2009 | 09:27 AM
You will be fine.. If there is any change it can be tuned out anyway....so no problem
Old Apr 3, 2009 | 11:11 AM
Luckycat's Avatar
I talked to Ray yesterday and he mentioned you have this new thermostat installed on your car. Do you know anyone with turbo that has one of this install in the car? I will install mazmart water pump and thermostat this weekend.
Originally Posted by Easy_E1
You will be fine.
Old Apr 3, 2009 | 11:30 AM
lucky: not sure if any FI guys are using it yet, you should check Mazmarts' thread on it to see who had them already.
you'll be fine with the thermostat + Int-X
Old Apr 4, 2009 | 10:25 AM
Luckycat's Avatar
Hi Jedi54,
I went back and read thermostat thread by Mazmart but could not find anyone with FI has this thermostat on their cars. May be I should PM Paul. Thanks.
Old Apr 4, 2009 | 10:48 AM
I have one in mine...car hasn't been started yet though Maybe today
Old Apr 4, 2009 | 11:14 AM
Luckycat's Avatar
Could you drop by and tell me later how the car behave. How this help with the coolant temp. And if the car run richer with coolant temp. I am curious. I will install mine either this week or next week. I am taking my car apart right now. Thanks.
What turbo kit you have in your car?
Old Apr 4, 2009 | 11:33 AM
Easy_E1's Avatar
We will be installing one in Mazdamaniacs car here today. I hope.
Old Apr 4, 2009 | 11:36 AM
I don't think that it will run richer....the thermostat will just open earlier when it's hot
Easy should be a good test mule...he will see hotter temps than I will here
Old Apr 4, 2009 | 11:41 AM
Easy_E1's Avatar
Driving last night temps ranged from 172 to 203 under load.. Yeah load.lol
Old Apr 5, 2009 | 12:59 AM
Luckycat's Avatar
Easy1, isn't that roughtly about similar temp as the stock thermostat? Can you describe what you mean by under load? Were you driving on the track or has been driven at high rpm for a while?
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
dbarber
Jul 25, 2015 01:34 PM
