XM Commander
Old Dec 20, 2003 | 07:08 PM
04RX800Miata's Avatar
Question XM Commander
So I'm installing a XM Commander... I'd like to wire directly to the fuse box panel... the radio unit is already out. Wiring is next. Any suggestions or alternatives???
1980 RX7
1985 RX7 GSL-SE
1992 MX6
1995 MX6
2000 Miata Special Edition
2004 RX8 Black GT 6 speed
Installed 17"wheels and Blizzak Winter TIres
Old Dec 21, 2003 | 05:25 PM
flyboyindy's Avatar
I had really good luck just taking it from the cigarette lighter. Have had it for 3 months and no problems... Where are you planning on installing it? Here are a few suggestions:
https://www.rx8club.com/showthread.p...threadid=13012
Old Dec 22, 2003 | 06:08 PM
Thumbs up XM Comander Installed, Thanks
Flyboyindy,
Thanks much for the information. After posting my request for instruction, I saw your pix and also some other information.
As you suggest, I connected to the cigarette lighter for ACC power and I connected to the radio connector, terminal 1B(bLue/Red)... Thanks Yuhki !!! Great Schematics.
...and as everyone else, the hidden bolt really was hidden until I removed the metal frame.
I noticed you and Allmazda mounted the antenna outside. I hesitated to push the rear glass or slam the cord. I tried installation inside on the rear shelf!!! Works fine...receiving all stations. loud and clear. I'll see what happens when I travel outside the area.
Right now, the main control box is mounted under the dash. Where did you mount yours??? I'm considering moving everything to the trunk... there certainly is enough wire!!!
Anyone know how to remove the center console??????
Old Dec 23, 2003 | 03:22 PM
flyboyindy's Avatar
No problem... I have the control box under the dash too... just didnt want to mess with taking the console apart... I always have an extra screw left over every time I take my cars apart... lol So I am trying not to take my car apart as much as possible =)
04Green
12
May 13, 2023 10:08 PM
dbarber
Jul 25, 2015 01:34 PM
foxman
17
Jul 10, 2005 02:10 PM
flyboyindy
53
Dec 27, 2004 03:34 PM
loco4rx8
Jan 15, 2004 11:05 AM
