yet another ticking thread...
Old Mar 20, 2009 | 04:23 PM
kellyrx8's Avatar
KS yet another ticking thread...
I searched and posted in a few threads...im pretty sure its plug related...however here is a video of the sound...
http://www.youtube.com/watch?v=biQJmu1SnlI
and then this sound when its in Drive...
http://www.youtube.com/watch?v=w9CfgXQjw3M
when its in neutral or park...it dosent do that...just drive...
Mostly looking for help on the 2nd sound...or unless you think my diag for the first is wrong too.
Thanks guys and gals.
Old Mar 20, 2009 | 04:32 PM
invasion08's Avatar
So there is none of those noises while in N or P. First place i would look is your motor mounts.
Old Mar 20, 2009 | 04:59 PM
volcomx31's Avatar
Silver Power
****..i have the exact same sound on my AT! good video..somebody help us out..
Old Mar 20, 2009 | 06:24 PM
volcomx31's Avatar
Silver Power
how many miles are on your car?
Old Mar 20, 2009 | 07:19 PM
teknics's Avatar
Certified Mazda Tech
Alright this is a reply to the original poster and to a PM i received from volcom, gonna try to cover all bases here to make sure you each receive the information you need:
First make sure that the basics are covered, obviously nothing loose under the car, plugs are good, wires are on tight, mounts are KNOWN to be good.
A quick description of a sure fire way to know it's not the engine mounts, requires only removal of two bolts and it's pretty easy:
Get a jack that can reach the oil pan, slide a piece of wood (wide and long as possible) between jack and oil pan. barely jack up motor.
Unbolt the two top mount bolts going from bracket to the mount, this will eliminate the mounts from the equation. Jack up the motor a little bit more.
Now start the car (rec. a friend bracing the motor from under the hood with his hands just in case)
If the noise is still there, mounts are eliminated as suspect.
Now I've personally seen this noise a few times, very few to be specific. We were able to trace it to the torque converter/flex plate area. Best way to try to verify this is by removal of an inspection plate with the car running and the noise happening, if the noise gets louder then that is where the noise is coming from, if the noise doesnt change then it's most likely internal trans noise.
On the few I had when I called for authorization for a torque converter and flex plate and all the necessary bits on one I was authorized to replace the whole trans...noise went away. On the rest I simply skip authorization and replaced the torque converter and flex plate and installed all new nuts. IIRC this got rid of the problem on all of the cars, i somewhat think that ONCE it didnt and we replaced the trans and the noise went away but that could've been a different car.
Anyway the dealer should be able to easily narrow a noise like this down.
If you're willing to bring it to the dealer and ask to go in the shop with the tech then demonstrate the noise to him. Once it's happening have him lift the vehicle in the air, ask him to remove the inspection plate on the trans and see if the noise gets louder or if its easier to pinpoint directly to the torque converter. Please when being involved with a tech while being intelligent don't talk down to them or anything, dont act "holy" etc, we're all just normal guys, most are into cars so throw out some stuff youd say at an rx8 get together or some current car news or something. Take a look at their box, we generally personalize our area so you can figure our interests. Basically let him know you're not some soccer mom bitching and moaning and also dont make it seem like you are only there to prove them wrong.
My hunch is you both need at least new torque converter and/or flex plates, a lot of techs will fubar your trans installing a torque converter so you'll wind up with a new trans anyway LOL.
As far as a dealership calling that normal, thats really easy to defeat, ask them to show you an auto rx8 making that noise.
Or escalate the problem, get the regional representative contact information or request he gets involved. Someone will eventually relay the proper repair info, sucks that it requires effort to get repaired but trust me it needs to be and eventually will be repaired if the necessary steps are taken and you dont let them brush you off.
Hopefully this will help you both get your problem resolved as well as anyone else reading this topic and having the same sound. I reiterate, that noise is NOT normal. It may not cause shift concerns but it isn't normal. Also any 2006-2008 guys there's a TSB regarding updated torque converters with an added damper due to a weird problem during 6th gear lockup. Search for torque converter thru the rx8 TSB's and see if any of the ones your car qualifies for (vin range etc) symptoms apply. If they do you may just have not noticed the other problems except this noise. Unfortunately no TSB's for a tick noise are around tho.
Kevin.
Old Mar 20, 2009 | 07:23 PM
kellyrx8's Avatar
just turned 60k this week
Old Mar 20, 2009 | 07:25 PM
volcomx31's Avatar
Silver Power
thanks a lot for this info! is this covered under warranty? i have 60k miles and i have an extended warranty up to 100k and my car is also pre-certified..
Old Mar 20, 2009 | 07:56 PM
kellyrx8's Avatar
same here...I JUST GOT mine... on the 9th...
and i purchased full bumper to bumper premium care on the car...it better be ******* covered or im going to be one pissed off ****
Old Mar 20, 2009 | 10:20 PM
kellyrx8's Avatar
noises are in D, and Reverse...not park or neutral
I hope its covered...
Old Mar 20, 2009 | 10:26 PM
shazy's Avatar
Check spark plug wires
Or look at that super long post.
Old Mar 20, 2009 | 11:29 PM
teknics's Avatar
just a note i left out of my post:
This of course if its the torque converter or trans at all, dont take my word as 100% diagnosis, noises are difficult to pinpoint in real life, over the internet they can be even trickier, the only way for a definite diagnosis is in real life. That's why I always say to make sure you take all steps available at the dealer, if you feel anything is out of the ordinary you are right in having absolute certainty that it is in fact normal.
kevin.
Old Mar 20, 2009 | 11:59 PM
Holy Mackrel!
That's one loud noise. Get hold of an old school guy like me and have him show you the ropes.
You need to search for that.
Old Mar 21, 2009 | 12:28 AM
first thing i would check would be plug wires..
the lower front one tends to come loose.
then the tightness of the plugs themselves.. it happens. both have happened to me..
Old Mar 21, 2009 | 01:10 AM
kellyrx8's Avatar
I checked the Tranny fluid and its way overfull...
Could this be causing the noise as well? overfull tranny?
Old Mar 21, 2009 | 01:21 AM
ZumnRx8's Avatar
RX8 & RX7 owner
I think Teknics is right
Old Mar 21, 2009 | 04:38 PM
kellyrx8's Avatar
yeah me too, car is going in next week to get looked at...
Old Mar 22, 2009 | 03:07 AM
volcomx31's Avatar
Silver Power
kelly, let me know what the dealership says and does..i am taking mine in as well..
Old Mar 22, 2009 | 06:21 AM
DOMINION's Avatar
I don't buy Kool-Aid
Do you have a MT or AT???
Old Mar 22, 2009 | 06:27 AM
invasion08's Avatar
They both have A/T's
Old Mar 22, 2009 | 12:08 PM
kellyrx8's Avatar
No problem!
I'm a little worried , the Last time i called the shop manager told me the ticking was from carbon ( it could be i guess...idk) and to run some fuel system cleaner through the tank. Well the last 3 tanks Ive used Lucas fuel treatment...
then he told me there is no point in letting the car warm up in the morning...just get in it and drive...
now from what I have read and understood from some people that are very familiar with these cars...you always let them warm up to operating temp then drive them...am I correct? because that's what I do every day
Old Mar 22, 2009 | 01:23 PM
volcomx31's Avatar
Silver Power
i warm up my car every time and i think you should too..i used BG 44K which is supposed to be a really good fuel cleaner and my car still feels the same..the issue is most likely my transmission
Old Mar 22, 2009 | 01:49 PM
kellyrx8's Avatar
oh most defiantly still tranny...just kinda wondering what the dealership will say next week lol
im going with what teknics said word for word...
Old Mar 22, 2009 | 02:07 PM
volcomx31's Avatar
Silver Power
also, my car makes that noise in all gears except parking and when i drive my car and push the engine the sound gets louder..is yours the same way?
Old Mar 23, 2009 | 12:10 AM
teknics's Avatar
it makes the noise when in neutral?
kevin.
Old Mar 23, 2009 | 12:12 AM
teknics's Avatar
Like i said, my diag can definitely be wrong, noises are very hard to diag without physically being there to hear. harder still with the car not on a lift for that kind of noise.
Take my advice on how to handle the situation however and whatever it turns out to be will get fixed. no matter what something on your car is making a noise it shouldnt be.
and dont tell them you talked to another mazda tech, they wont be faster to help i can tell you that.
kevin.
