Coolant light
Old Mar 16, 2009 | 03:34 PM
04rx8gr's Avatar
Coolant light
so just got the new engine in about 200 miles ago and ever since its been put in. . I keep getting the coolant light turning on when im about 4500 RPM and holding that for a while. . .Then I take it down to 1000 RPM and it goes off. . . . Checked coolant level and its just fine. .
Old Mar 16, 2009 | 03:52 PM
StealthTL's Avatar
The float switch in the reservoir goes bad - common problem.
1 - Fix under warranty,
2 - buy whole new overflow bottle yourself or
3 - live with it.
Old Mar 16, 2009 | 03:56 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
my light was psycho before, but I just added a little distilled water in the coolant tank and the light never came back... hope this helps
Old Mar 16, 2009 | 04:23 PM
Old Rotor's Avatar
+1....this has fixed most of them!
Old Mar 16, 2009 | 04:48 PM
04rx8gr's Avatar
Sweet well ill show mazda when I got in on monday
Old Mar 16, 2009 | 05:14 PM
myriadshalaks's Avatar
rot8ing
mine does it too. 07. it also goes off if you wiggle the steering wheel dramatically like an old movie while doing over 35.
i'm living with it for now. probably get it fixed next oil change.
Old Mar 16, 2009 | 05:15 PM
rot8ing
about how much distilled water?
Old Mar 16, 2009 | 11:08 PM
Old Rotor's Avatar
I would try about 16oz. See if this makes any difference if it's too much it will go out the overflow like it's made to do.
Azki23
Jun 27, 2018 03:48 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
