check engine light help
Old Mar 16, 2009 | 09:27 AM
brandon1231's Avatar
Unhappy check engine light help
I was using regular gas in my 8 and the check engine came on. someone told me to start using premium gas to fix it. The 2nd fillup of premium and it went off. Ive continued to use premium and in the past month, its came on and went off twice. It'll stay on for 2 or 3 days then go off. Any ideas on why it would be doing that? Thanks
Old Mar 16, 2009 | 09:29 AM
expo1's Avatar
He's as bad as Can
without knowing the exact CEL code it will be hard to offer advice.
Old Mar 16, 2009 | 09:32 AM
I believe it was P2096
Old Mar 16, 2009 | 09:38 AM
expo1's Avatar
He's as bad as Can
A search brought up this thread https://www.rx8club.com/series-i-tech-garage-22/engine-light-2096-code-162627/
How many miles on your 2004? You might just need either a MAF or o2 sensor, both are easy to change.
Old Mar 16, 2009 | 09:47 AM
myriadshalaks's Avatar
rot8ing
i would check my engine.
Old Mar 16, 2009 | 11:06 PM
teknics's Avatar
Certified Mazda Tech
p2096, i'd suspect an intake leak somewhere. the freezeframe data would be super handy as we could see what fuel trims the car is seeing, as well as a log of the rear o2 sensor which could be out of whack and reading way out of spec.
kevin.
Old Mar 22, 2009 | 03:59 PM
GTX723's Avatar
Hi Teknics,
I didn't get that stuff about freezeframe data (but the song popped into my head). I'm guessing it's something the dealer would do?
I replaced the rear o2 sensor in Dec. and the ig. coils in Nov.
Last Saturday, after 2 hours of driving on the interstate, the CEL came on , reading 2096. What is my first step?
Thanks, Paul
Old Mar 22, 2009 | 04:56 PM
Check for intake leaks.
Coils may ned to be replaced.
If you get the code again after fixing tese two then its the O2 sensor.
Don't worry about it Paul unless the code pops up again with another cell.
But do check for intake leaks.
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
akagc
Aug 11, 2015 07:07 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
