Electrical problem?
Old Mar 8, 2009 | 07:50 PM
ZmFnZm's Avatar
Electrical problem?
I took my 8 out of winter storage on Friday, got her started right away (first crank on the starter!) Let her warm up, then went out for a cruise.
Took it nice and easy for the first half an hour or so, just to get her going again. Then i hit the 407... after booting it along for a while i took the exit ramp at Bronte Rd. and decided to test the breaks. Full on the breaks till i dropped down to about 30km/h (keep in mind it was late, and absolutely no traffic around me) when all of a sudden under hard breaking almost all of the warning lights come on!!!! I get off the breaks and the lights go out.
The engine ran normally through the whole thing. Then for the rest of the drive everything was normal.
Anybody got any ideas????
Thanks for the help!!
Old Mar 8, 2009 | 08:35 PM
Thumper3322's Avatar
Did it stop/slow down tho? Just keep driving it, go easy on them and in few days try again. No idea haven't heard that one before.
Old Mar 8, 2009 | 08:45 PM
Sanguine's Avatar
Was it sort of like this but everything went back to normal afterwards?
Anyhow, I was conned into giving a friend a ride to school this morning at 6:30. Car started fine, maybe a few extra cranks before the engine gave in and stopped being stubborn but all was normal.
I was coming back from Oakville on the QEW/403 when the radio volume went down by itself and the battery dash light went on. Me thinking the car should charge it while driving didn't really think much of it. Got to around Appleby or Walkers Line when the center console went dark, radio went off and the TPMS and DSC lights came on. About 30 seconds later the coolant and ABS lights went on. I shut the heater and fan off hoping that I could nurse the damned thing to the Hamilton Mazda dealer about 5 minutes further down the QEW. Just before the 403/QEW split the headlights and will assume taillights, dash and the auto dimming mirror LED died. I decided to stay on the 403 because if the car gave up on the Skyway bridge, I'd be killed by traffic. The power steering and engine light came on about 30 seconds later and lost power steering. Realizing I'm fucked and can't pull over to the side of the highway because the shoulder isn't ploughed I have to wait under the next exit (4 kms) until I could try and save the engine because I'm thinking sooner or later the ECU is going to cut out and something rather expensive is either going to starve or explode.
After a 3.5 hours and 13km walk I got home.
**** sakes...
Old Mar 8, 2009 | 08:48 PM
rotarygreg's Avatar
grass hopper
didnt you have some wiring issues a while back? Also, do you really mean almost all the warning lights, or are you exadurating? For example, are we talking like the brake (ebrake) and ABS warning lights and like the DSC and traction lights. or everything, battery, oil, coolant?
Old Mar 8, 2009 | 08:56 PM
ZmFnZm's Avatar
The car was running beautifully, and then when i was full on the brakes the battery, coolant, and a couple of other lights (I'll have to take another look at the instrument cluster in the morning to remember which ones) came on. But then when i got off the brakes all warning lights went off.
The whole time this was happening the car was purring like a kitten, nothing wrong with any of the mechanical systems.
And yes i have had electrical issues with my car. The heater control module was replaced under warranty and then there was my DRL issue. That one was finally tracked down to a faulty ground connection in the parking break mechanism underneath a relay switch.
Old Mar 8, 2009 | 09:08 PM
rotarygreg's Avatar
grass hopper
did you have the clutch in? i could see the bat light coming on if you stalled the engine if you were braking hard in gear and the wheels locked for a second, then you let off the brake and the engine will start running because the wheels rolling again will start the motor running. just a thought.
Old Mar 8, 2009 | 09:19 PM
ZmFnZm's Avatar
She was in neutral... and like i had said the car was, and staid in perfect running condition the whole time.
I don't really get it?
Old Mar 8, 2009 | 09:49 PM
rotarygreg's Avatar
grass hopper
weird....wait til this crappy rain clears up and try it again.
Old Mar 9, 2009 | 10:03 AM
Footman's Avatar
Dodging those Corollas
Maybe under hard braking, You have some loose electrical connection somewhere in the engine bay, and the force of inertia was moving the connections apart?
Remember, there's significant G-forces in deceleration; way more than acceleration.
Old Mar 9, 2009 | 10:29 AM
ZmFnZm's Avatar
Yeah that's kinda what i was thinking too, but it only did it that one time, and I really threw the car around (in a safe way) after that to try to reproduce the glitch...
Old Mar 9, 2009 | 11:49 AM
01Racing's Avatar
A simple explanation if the car was in gear would be the rear wheels locked and caused the engine to shut off momentarily. That would set off all your light and when you got off the brakes the engine would run and everything would be normal again.
Old Mar 9, 2009 | 12:34 PM
ZmFnZm's Avatar
Very true, the problem with that is that i wasn't in gear when i hit the breaks.
Old Mar 9, 2009 | 02:31 PM
01Racing's Avatar
Well then I give up! (lol)
Old Mar 9, 2009 | 04:35 PM
rotarygreg's Avatar
grass hopper
haha al, nice try. thats what i was getting at with my best guess.
Old Mar 9, 2009 | 04:40 PM
Silver06's Avatar
Zoom Zoom....
Perhaps over the winter your battery voltage decreased (or the battery was disconnected) and the car forgot the 'learned' fuel trims. It takes several drivecycles to relearn.
After a battery disconnect, I had a similar problem - stalled while coming to a stop. Restarted just fine, and never came back.
Old Mar 9, 2009 | 04:52 PM
rotarygreg's Avatar
grass hopper
read more carefully. he said the engine runs fine. the only problem was once under hard braking a bunch of warning lights came on.
Old Mar 9, 2009 | 05:13 PM
Silver06's Avatar
Zoom Zoom....
I can read fine, thanks....
I'm only putting out a thought: The engine computer thought it was stalling - when suddenly the load dropped off when he pushed in the clutch. The engine figured it out, the engine stayed running, and the problem has not reoccurred.
Or, you could trace every wire in the CAN Bus system and ECU. lol.
Old Mar 9, 2009 | 06:01 PM
AndrewE's Avatar
Yellow Fever
check your battery connections, mine were loose and caused the dash lights to go nuts occasionally
Old Mar 9, 2009 | 06:40 PM
ZmFnZm's Avatar
worth a shot, but i tightened them myself only 45 min earlier.
Old Mar 9, 2009 | 06:41 PM
ZmFnZm's Avatar
but that's not all of my problems, looks like i picked up a nail during that drive...... now i've got a flat nearly new KDW on my car...ARGH!!!!!!!
Old Mar 18, 2009 | 04:32 PM
ZmFnZm's Avatar
And the saga continues... Twice in the last week the car has stalled out completely on the off ramp, once on the QEW and today on the 407. Taking her in to Oakville Mazda for her post hibernation oil change on Saturday and they are going to look at what is going on.
... and no i didn't leave it in gear when i came to a stop, the car was in neutral both times.
Crossing fingers it's nothing serious, but the car still has 110K of warranty on it so i should be good
Old Mar 18, 2009 | 04:49 PM
Footman's Avatar
hehehehehe... rough idle?
Old Mar 18, 2009 | 06:08 PM
ZmFnZm's Avatar
yeah, a little bit...... coils?..... ARGH.....
Old Mar 18, 2009 | 06:30 PM
Footman's Avatar
1) did you clean your MAF?
2) did you check your air filter element?
3) did you examine your intake accordians for any holes, broken screens, oddities?
Old Mar 18, 2009 | 08:12 PM
ZmFnZm's Avatar
MAF is clean, checked it last summer and the car has been in storage all winter,
Air filter is clean, and i have an HKS intake on the car, so no accordions to get punctured.
