Faint squeaking noise...
Old Mar 6, 2009 | 04:50 PM
xdj_jdx's Avatar
Pew Pew
MN Faint squeaking noise...
There is a Squeaking noise coming from the engine bay when im at idle was wonderingif this is just a bad belt if so what do i look for on the belts to determine if they are bad thank you.
Old Mar 6, 2009 | 08:06 PM
DOMINION's Avatar
I don't buy Kool-Aid
It could be one of two things.
1. Belts or 2. see attchment-red circule yup, its going out.
Old Mar 6, 2009 | 08:07 PM
DOMINION's Avatar
https://www.rx8club.com/series-i-tech-garage-22/lost-air-pump-88157/
-Gil
Old Mar 7, 2009 | 11:28 AM
EDZRIDE's Avatar
2005 White GT
Spray some WD40 on each belt (with the engine idling); if the squeak goes away, you found the culprit! It may only need to be adjusted.
Old Mar 7, 2009 | 11:38 AM
Ryoma-kun's Avatar
Does the squeaking noise disappear when if you engage the clutch?
Old Mar 7, 2009 | 11:58 AM
shaunv74's Avatar
Power!!
Mouse in the house?
Old Mar 7, 2009 | 12:27 PM
xdj_jdx's Avatar
Pew Pew
no its still there with clutch in its very faint i think maybe its the pulleys...? i had my mazda dealership check my belts they said they looked fine. im gonna try the wd40 on the pulleys and see what happens. Thanks you guys for the responses!!
Old Mar 8, 2009 | 12:22 PM
EDZRIDE's Avatar
2005 White GT
Spray the belts while it's running.
Old Mar 8, 2009 | 05:26 PM
dirtywrench77's Avatar
the water pump is bad for making noise like that right before it starts to leak.take off the belt and start the car and see if the noise goes away.if it does the take off the pully and look for crusties at the vent hole under the neck.if there's crusties change the pump.its really easy.
Old Mar 11, 2009 | 10:43 PM
DOMINION's Avatar
Could it be his SSV getting stuck like Gomez did? or this guy https://www.rx8club.com/series-i-trouble-shooting-95/ssv-acuator-d-168277/
rotor001
Jan 16, 2016 11:27 PM
Forevermore
Sep 20, 2015 01:04 PM
thewatcher101
Aug 4, 2015 10:42 AM
LiftOff
Jul 16, 2015 08:24 PM
dj.stains
May 3, 2010 12:14 AM
