Cargo net
Old Dec 16, 2003 | 07:27 PM
Tamas's Avatar
Registered Lunatic
Question Cargo net
Now here is a strange question (maybe). Who had their cargo net installed by themselves? I got one from Trussville, and while the upper two hooks were a doddle to put in, the lower two seem to be a real bitch. The instructions say to just push firmly into the hole from which you took out the plastic rivet. Yeah right... also, they mention that "supporting the plastic panel from behind during installation may be necessary". WTF??? How can someone support the panel from behind when it is installed into place???
The rubber grommet with that metal insert is too big to be pushed into the existing hole, and I already messed up one of those grommets while trying. Did anyone have a similar problem and what did you do to overcome the issue?
Old Dec 16, 2003 | 07:32 PM
brothervoodoo's Avatar
RainMan is Back
Hi Tamas, this has been mentioned before by 2 other members trying to do their cargo net install. You will need to open the 2 bottom holes up more, may need to do some drilling. Do a search and see if you can find the posts. good luck!
Old Dec 16, 2003 | 07:34 PM
RainMan is Back
https://www.rx8club.com/showthread.p...ight=cargo+net
https://www.rx8club.com/showthread.p...go+net+install
Old Dec 16, 2003 | 07:45 PM
Tamas's Avatar
Registered Lunatic
Doh! Thanks... should have searched first. :o
Now the only thing is that as mentioned, I already messed up one of the grommets while trying - and not only that, but while doing so, I accidentally dropped the tiny nut (that was inside the grommet) into the dark depths of the trunk... ever noticed how easy is to lose little nuts, bolts and the like in a car?
So I guess now I have to find some alternate method to secure the lower two anchors - something that will make them stay in place just as snug as the upper two. Damn!
Old Dec 17, 2003 | 01:17 PM
Haze's Avatar
Man, don't open the holes up further. I just took a hammer and gently tapped the two pieces into the holes then tightened them up. It worked fine.
Old Dec 17, 2003 | 01:29 PM
Lock & Load's Avatar
Talking
Tamas
Cargo nets hmmmmm , are you planning to go fishing in the Danube???
MIKLOS
Old Dec 17, 2003 | 05:46 PM
Tamas's Avatar
Registered Lunatic
Not really... I just have one in the Probe GT and found it very useful when buying groceries... you know, the RX-8 as grocery getter :p
As for tapping - I tried that... no dice. I tapped, and then even BANGED on it - wouldn't go in place. Actually, that was the way how I messed up that grommet.
Hey, by the way... if you're Miklós, then your English name should be Nicholas, not Michael :p
Old Dec 17, 2003 | 06:01 PM
Talking
Tamas
My birth certificate says NIcholas Michael , i use Michael otherwise people call you nick , mick etc .
Anyhow thanks for the interpretation .
MIKLOS
Old Dec 18, 2003 | 05:01 AM
8_wannabe's Avatar
Go baby!
I tapped 'em in with a hammer; there's no give at first then they go in all at once, nice and snug.
Old Dec 18, 2003 | 06:15 AM
rxeightr's Avatar
M0D Squad -charter member
I was unsuccesful with doing this, so I am one of the ones that drilled a larger hole. This was back in August & it worked perfectly for me.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
mitchrx8
Sep 13, 2015 08:05 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
