Getting new shocks ..but which?
Old Feb 17, 2009 | 12:32 PM
FlashFire8's Avatar
RARE POSTER
I am deciding on the Koni - Tokico D Spec - or the Bilstein
im shoting for Koni
im going for a stiff setup in road racing
what do you guys recommend from experience?
if there is a better shock let me know
ill be using stock springs until i test these out and see what spring i would want
-Thanks !
Old Feb 17, 2009 | 02:17 PM
Optical TDI's Avatar
Tokioc d-specs for you can easily adjust the rears with the extensions that are available. The rear Koni's can't be adjusted without taking the dampers. That was a deal breaker for me on the Koni's.
Buy your spings now and do it at once. The fronts are easy and a one man job, but the rears a little tricky espcially with the extenstion adjusters that you need.
Old Feb 17, 2009 | 02:30 PM
TopGear8's Avatar
mkuhnracing.com
Koni Yellows are a bit stiffer than the D-specs, so they will be a bit better for road racing.
Old Feb 17, 2009 | 05:11 PM
True that, but if you're OCD with changing settings, you'll be pissed with the Koni's as there's no easy rear adjustability. If that's not a problem, Koni's are your best bet.
Old Feb 17, 2009 | 05:21 PM
c0ldf1ame's Avatar
konis and bilsteins are both rebuildable, tho i think bilsteins are easier to rebuild than konis, i dont know about tokicos
Old Feb 17, 2009 | 09:16 PM
FlashFire8's Avatar
RARE POSTER
I dont mind the hassle to adjust them
I have a shop were i do all my work and like to take my time
im going with konis
Old Feb 18, 2009 | 07:22 AM
Big Money Pit's Avatar
while we're on topic, what's a good spring to mate up with the koni's?
something that offers a modest drop.
Old Feb 18, 2009 | 10:24 AM
TopGear8's Avatar
mkuhnracing.com
^Tein H-Techs.
Old Feb 18, 2009 | 10:27 AM
for autocross?
Old Feb 18, 2009 | 06:53 PM
NotAPreppie's Avatar
What am I doing here?
I think most ST autocrossers end up with a full coilover system. You might want to PM Mr. Pockets about his experience with Stance.
Nisaja
15
Nov 21, 2015 10:30 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Paul_Y
Sep 21, 2015 02:23 PM
FoxRacer600RR
Aug 31, 2015 06:32 AM
