Replace Heat A/C Controller Panel:
Old Feb 13, 2009 | 07:03 AM
PaPaBear's Avatar
PaPa Bear
Anyone know how to get access to this part. I have to replace it.
Thank you.
Old Feb 13, 2009 | 07:39 PM
Juice's Avatar
I made some poos
You can buy it online at online mazda parts. Cost is somewhere around 240 dollars though. If you are having trouble with it (intermitten heat/AC), check the DIY forum for the fix. The thread is a sticky if I remember so you shouldn't have any trouble finding it. The fix involves soldering 3 connections that are known to crack and come apart. It is an easy fix as long as you can solder even remotely decent.
To replace it, the radio needs to come out. There are a couple of connectors on the unit itself and it screws into the back of the radio faceplate. It is really apparent on how to take it out once you have the radio removed.
Old Feb 16, 2009 | 11:28 AM
heyarnold69's Avatar
Rotary wanabee
there is a fix it yourself linkage on the site... I need to do it anyway... if mine works out ill let ya know.. apparently its really easy
Old Feb 17, 2009 | 07:19 AM
PaPaBear's Avatar
PaPa Bear
Thank you. I have the part from a wholesale house.
drebbrnator
Dec 27, 2018 07:02 PM
RicerX1
Jan 11, 2016 05:59 PM
PotatoCannon
Sep 6, 2015 11:48 AM
dancingdan42
Aug 19, 2015 09:29 AM
mazdaverx7
Jul 21, 2015 07:31 PM
