Help tires asap
Old Feb 7, 2009 | 05:17 AM
Semiazas's Avatar
The Dark Carnival
Help tires asap
Hey my rear tires are all gone on my stock rims. In my garage i have a set of 215/35/18 and i know the stock are 225/45/18 is there anyway the 215/35 would fit on the rim good enough to be used temporarily?
Old Feb 7, 2009 | 08:41 AM
imput1234's Avatar
I ♥ Drifting!!!
Yeah, you can stretch the on. You'll be fine, it's a mild stretch.
Old Feb 7, 2009 | 10:25 AM
Semiazas's Avatar
The Dark Carnival
Thanks so much my tires are down to nothing and i got them being put on now so finally i can drive agian without being scared.
Old Feb 7, 2009 | 11:35 AM
Wargoose's Avatar
That's actually quite a large change in rolling diameter. You're going from a 26.0" OEM size to a 23.9" with those new tires, resulting in an almost 8% speedometer error (in your favour, mind you - speed will read higher than your actual speed).
I wouldn't recommend it.
Old Feb 7, 2009 | 12:51 PM
Socket7's Avatar
ಠ_ಠ
Tires that skinny will make it very easy to curb your wheels as well.
But if it's between driving on bald tires and tires that are a bit to narrow, i'd pick the narrow tires with decent tread every single time.
Just watch out for potholes. i don't think you have much sidewall on those.
If you can afford it, I would go with 245/40/18 I think it's the perfect size for the OEM rims.
Old Feb 7, 2009 | 02:08 PM
NotAPreppie's Avatar
What am I doing here?
Are you planning on replacing only the rears or all four? I don't recommend that much of a diameter change between front and back if you have DSC.
Old Feb 7, 2009 | 03:57 PM
GaMEChld's Avatar
Registered Noob
+1 for 245/40/18's
Hunterkelley24
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
