Do I need to change oil right after Sea-Foaming?
Old Jan 12, 2009 | 08:27 PM
Jonathan11's Avatar
Pain Is Weakness
Question Do I need to change oil right after Sea-Foaming?
I will be Sea-Foaming my car between tomorrow and Friday i would like to know if it is necessary to change my oil right after or can i run the car with this stuff in it. I plan on putting it through the vacuum line, and some in the gas tank. Any input would be greatly appreciated, Thank You.
Old Jan 12, 2009 | 08:51 PM
no.
Old Jan 16, 2009 | 08:47 AM
mazdaverx7's Avatar
RX-Heaven
^^the man is right..he seems to always have the right answer... but at any rate, the reason is that because teh sea foam is not getting into your oil and into the combustion chamber only, it is not necessary to change your oil. you oil will not be contaminated by the seafoam.
Old Jan 16, 2009 | 09:39 AM
It's the beer that make him smart!
Old Jan 16, 2009 | 09:45 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
It can dillute and enter your oil... ever seen the oil after using the water method? milky... I can smell the sea foam in the oil after I do it. One can probably wont hurt, but I have to disagree with swoope on this one from personal experience. You should change it.
Old Jan 16, 2009 | 10:02 AM
mazdaverx7's Avatar
RX-Heaven
i guess it would depend on how much sea foam you are using and how you are using it.
Old Jan 16, 2009 | 03:50 PM
Nubo's Avatar
Lubricious
Why not follow the TSB procedure, get it into the chambers and let it soak? Running it through the engine via vacuum line might create a nice smoke show, but doesn't give it much time for softening carbon deposits in the seal grooves.
Old Jan 16, 2009 | 04:29 PM
Jonathan11's Avatar
Pain Is Weakness
Putting it through the chambers huh? Is this better than through the VAC? and why?
Old Jan 16, 2009 | 04:32 PM
Jonathan11's Avatar
Pain Is Weakness
Okay i just check the TSB, the one that i have says to put it through the VAC line. Could you send me the link to the TSB you are referring to, i have a feeling mine is incomplete.
Old Jan 16, 2009 | 06:19 PM
04RX8man's Avatar
Rotary Powered Countryboy
I know of ppl taking out the plugs and putting some in the plug holes also drawing some through the vac lines and letting it sit over night then firing it up!
Old Jan 16, 2009 | 11:11 PM
and have you seen the oil after the h2o treatment after it has been driven and up to operating temp for a while.. the h2o goes away like the milky stuff on the dipstick..
it the best method were to be done would be to seafoam it just before you needed to change the oil.. but that is just me..
Skyl3r
Dec 2, 2019 04:51 PM
uZu
Dec 30, 2015 12:35 PM
motohegg
Aug 23, 2015 08:14 AM
Modern2Strokez
Aug 16, 2015 01:07 AM
dohon
Aug 1, 2015 01:46 PM
