Fluid Change Intervals
Old Jan 11, 2009 | 05:22 PM
Hotsauce's Avatar
RRDI Member
When is the right time to change your brake and coolant fluids? In the manual is says to change the fluid at 60k miles then every 24 months after. Brake fluid I believe is also after 60k miles. The reason I'm asking is that I have a 2004 but with few miles, under 25k. Should I have the brake and coolant fluid changed soon?
Old Jan 11, 2009 | 05:43 PM
bse50's Avatar
#50
You can wait to do the brake fluid replacement when you change your brake pads if you don't track the car or such. It should be a pretty sealed system so changing is not really necessary, if the car brakes!
Changing the coolant might be a good idea though since some coolants have a determined life.
Old Jan 11, 2009 | 05:49 PM
Usually 2 years for coolant and brake fluid.....so you should change both...
The 06+ cars came with FL22 coolant..long life stuff...supposed to last 4 years?
Old Jan 11, 2009 | 07:04 PM
ken-x8's Avatar
Would you believe ten years? Then every five years after that.
Regular coolant is four years for the first change, then every two years.
Ken
Old Jan 12, 2009 | 08:28 AM
Hotsauce's Avatar
RRDI Member
Can you put FL22 coolant in a 2004? I'll think about changing the brake fluid myself and maybe putting on some SS lines. Any recomendations for brake fluid? I'll maybe be doing a few track events throughout the year.
Old Jan 12, 2009 | 05:18 PM
04RX8man's Avatar
Rotary Powered Countryboy
for Brake fluid DO NOT GET DOT 5 OR 5.1 you will ruin things in ur brake system i.e. all rubber seals! A DOT 3 or 4 Synthetic is best for DD and tracking!
Old Jan 12, 2009 | 07:54 PM
ken-x8's Avatar
FL22 is green glycol antifreeze, pre-diluted to (I think) 55%. As long as your car has green antifreeze, you can use it. Don't if you've got orange. If you didn't start off with FL22, though, it's probably cheaper to buy name brand straight antifreeze and dilute it yourself.
Since you're going to do some track events, try browsing the competition forum for specific brands of brake fluid, and also for coolant recommendations.
Ken
LB2739
Jul 9, 2019 02:25 AM
Chapsy
Sep 22, 2015 09:57 AM
Irvinb16
Sep 11, 2015 10:27 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
