OMP sensor modification for Top Mount Turbo & SOHN adapter.
Old Jan 10, 2009 | 08:46 PM
m4f1050's Avatar
Recently I installed a SOHN adapter and an SFR Turbo Kit. The problem with these two coexisting is the OMP sensor plug, gets in the way of the exhaust pipe. In order for me to get them both installed was to modify the OMP sensor and install it upside-down (cables towards the top.) I cut the plug off the sensor leaving the 3 pins exposed (you only use the 2 outer pins.) I then soldered a wire on each long enough to reach through the back of the adapter so the cables did not touch the exhaust and bend them inward (towards the motor.) Then I covered the entire OMP section, including the SOHN adapter and hose with high-temp resistant fabric sold @ Adavced Discount AP. On mine I went the extra mile and from a 2nd sensor I added the plug at the end of the cables so I didn't splice the stock plug from the wiring harness. Here is a pic of my modified sensor:
Old Jan 10, 2009 | 08:50 PM
nuke0907's Avatar
Never Blend In
good idea.
its hard to tell from the pics though. try using your flash and a different background.
Old Jan 10, 2009 | 08:55 PM
m4f1050's Avatar
I didn't have a camera at the shop, this was using a phone ! :O
Idea is to use what used to be the top of the sensor at the bottom, occupying less space. And in order to do this you have to cut off the plastic part of the plug, then bending the pins towards the motor and soldering wires to it and of course shielding it afterwards.
Old Jan 10, 2009 | 08:56 PM
mysql's Avatar
Doppelgänger
lets see some installed photos
Old Jan 10, 2009 | 09:00 PM
nuke0907's Avatar
Never Blend In
is Richard Sohn the only person that sells the adapters, or is there any vendors that have them?
Old Jan 10, 2009 | 09:01 PM
mysql's Avatar
Doppelgänger
funny.
even on his website he doesn't call it the sohn adapter. He calls it "Adaptor for RX8 Renesis"
Old Jan 10, 2009 | 09:02 PM
m4f1050's Avatar
I already installed everything (water outlets & hoses) you wont see much, but I will take pics tomorrow AM, all you will prob. see is the covered OMP with high-temp fabric and exhaust right next to it...
I don't know of any other provider for the SOHN adapter. I got it from him (or his company don't know who I emailed...)
Old Jan 10, 2009 | 09:04 PM
nuke0907's Avatar
Never Blend In
i think he has an email address or something on his site to order it from. i think someone on 7 club did a GB one time for <$96 msrp.
Old Jan 10, 2009 | 09:05 PM
m4f1050's Avatar
2-stroke oil canister I used... (center one, right one is Oil Catch and left is still on the works for the windshield washer fluid, need to make adapter for pump.) Still have room for a 4th one Maybe a radiator reservoir?
Only pics I took when I installed turbo: http://xtreme-toyz.net/sfr-turbo
Old Jan 10, 2009 | 09:09 PM
nuke0907's Avatar
Never Blend In
i like turborx8's tank setup before he got the mazsport canisters.
Old Jan 10, 2009 | 09:19 PM
m4f1050's Avatar
Reminds me of my jetskis... Check oil every time I fuel... LOL
Will take better pics (of finished product) when I'm done with it...
Old Jan 11, 2009 | 10:43 PM
rotary.enthusiast's Avatar
The Local Idiot
Do you know where he got those tanks? I like that a lot actually.
Old Jan 19, 2009 | 04:34 PM
nuke0907's Avatar
Never Blend In
do we need the adapter with the adjuster or is the adjuster not required?
Old Jan 20, 2009 | 08:37 AM
m4f1050's Avatar
I was asking where the adjuster goes because if it goes in between then there is no space for all 3 (sensor, adapter and adjuster) The adjuster is supposed to set the OMP to a fixed amount of oil injection used for aviation (renesis at high rpm all the time)
Old May 5, 2009 | 02:31 PM
JMKuco's Avatar
Rotary engine addict
so is it possible to "transform" an oil catch can to a windshiled reservoir ?
Old May 8, 2009 | 01:49 PM
Race Roots's Avatar
Former Sponsor
Yes it is but adapting it isnt the easiest.
I have a trio set that is already adapted to work with windshield reservoir
Old Oct 30, 2009 | 01:42 PM
m4f1050's Avatar
I am looking for the Mazsport radiator reservoir. I would like to remove the ugly white plastic one from the from since I relocated the battery to the back and added 2nd terminals for 2 batteries instead of 1.
Old Nov 11, 2009 | 05:23 PM
always.anthony's Avatar
is looking for his torque
thread resurrection, i too have this same question!
Old Nov 12, 2009 | 05:30 AM
paulmasoner's Avatar
Asshole for hire
its not needed. if you have the AP you can adjust you OMP output that way. the adapter allows you to inject 2-stroke, the adjuster allows you to alter how much oil you are injecting
Old Nov 12, 2009 | 12:18 PM
JMKuco's Avatar
HI !
I am working on the radiator reservoir !
I took out mine and add one in aluminium
but had to remove some parts ...more info + picts by this week end
Old May 12, 2010 | 09:20 PM
m4f1050's Avatar
Windshield washer canister, finished. Drilled 1 1/4" hole, inserted the rubber seal that came off of original canister, used some grease to insert the washer pump, all nice n fit. Works like a charm!!! Forgot to post pics... Here is pic:
Old May 12, 2010 | 09:43 PM
m4f1050's Avatar
HI !
If you went this route.....
FAIL
I am fabricating a 4th canister like the other 3 I have in my 8.... Will keep you posted how it goes....
Old May 14, 2010 | 03:26 AM
m4f1050's Avatar
FAIL
Click--> Update <-- Click
Old Dec 9, 2010 | 11:57 AM
Nemesis8's Avatar
Bigus Rotus
How do you know the sensor can work upside down? Seems odd to me....
Old Dec 9, 2010 | 03:17 PM
m4f1050's Avatar
It has a groove all you do is turn it up-side down and it works the same. I tested it on my own car, worked flawlessly. I now need to premix, installing a 20B on my car now...
What I did was took both screws off. Noticed how much winding it had, turned it around 180 degrees with same windings where the groove snapped in, then put back the screws. Car never threw CEL, smoked a little like before and the oil consumption stayed the same.
