RX-8 Power Control Module (PCM) Flash Service
Old Jan 5, 2009 | 02:52 PM
2005Rx8bn's Avatar
Hey i am new, but i am planning on buying an rx8, I was wondering there are many deals out there like 05 with 27,000 for only 14k. So I was wondering anyways to find out if there is something wrong with the car.
also referring to the title RX-8 Power Control Module (PCM) Flash Service i wanted to get it and I wanna know what it does.
Old Jan 5, 2009 | 02:55 PM
first off, welcome!
There are plenty of good deals on used RX-8's right now. Where are you located?
There is no real PCM reflash service. The dealership does flash the PCM from time to time if there is a Service Bulletin or recall.
Are you referring to something you can buy on our own to check the PCM?
If so, then the AccessPort might be for you. It can read Check Engine Codes, Monitor data as you drive, and you can even flash the PCM to different parameters. (this is something you should do only after you've studied the car for a bit. Changes to PCM can cause problems if you are not familiar with tuning)
Old Jan 5, 2009 | 06:03 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah to flash yourseflt the accessport is the wa to go just for pcm flashes that the dealer feels are better than the current one then the dealership will do that but will post a tsb for it!
Old Jan 5, 2009 | 07:12 PM
2005Rx8bn's Avatar
Thanks for the welcome. I read it lets people rev to 9700 rpm. heres a youtube of someone doing it. http://www.youtube.com/watch?v=5cFWDJlRoAo
Do you need it to rev that high?
Also heres the link to two cars i am looking at
http://tinyurl.com/8w5vu6 being the first one i want
http://tinyurl.com/9x759z worst comes to worst
Old Jan 5, 2009 | 07:42 PM
Marklar's Avatar
Is there any reason to rev higher than 9500 on a stock NA engine?
Old Jan 5, 2009 | 07:45 PM
Jasonawojo's Avatar
Not that I know of, but that video actually only revs to 9300 [Racing Beat Flash]. The tach is just off a few hundred rpm on the high side.
Old Jan 5, 2009 | 07:46 PM
rowteree's Avatar
there is no benefit reving higher than 9100 rpms on a stock engine even with an aftermarket flash tuner. You don't make any more power beyond that point. You are just causing harm to your transmission if you attempt revving beyond that point
Old Jan 5, 2009 | 07:47 PM
alnielsen's Avatar
There is a reflash service. It is offered by Racing Beat.
Here is a link to their page: http://www.racingbeat.com/FRmazda4.htm
Old Jan 5, 2009 | 09:00 PM
04RX8man's Avatar
yeah max power is made at like 8700 rpms past that it just drops off anything in the 9700 area is just a waste of gas and start to break stuff
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
akagc
Aug 11, 2015 07:07 PM
whitelight42
Jul 22, 2015 04:13 PM
