Drained out RP Synchromax for GM Syncromesh + FM
Old Dec 17, 2008 | 10:24 PM
CaliAgents1688's Avatar
I've had some very slight grinding issues going into 3rd as it doesn't happen all the time and the grind only occurs for a fraction of a second.
Around 37k miles, I drained out the oem stuff for RP Synchromax since that is what I used in my BMW with excellent results. Initially, the shifts felt very smooth however I was still getting the 3rd gear grind. A couple of weeks ago, I up-shifted from 3rd to 4th at high rpms and grinded fairly bad. This is when I decided to go home and do some research here on RX8Club for a fluid which is compatible with our tranny and has proven itself over the long haul.
I settled with GM Syncromesh + Friction Modified. Expensive stuff at about $14 a quart at your nearest GM dealer! I also swung by Autozone and picked up a couple of bottles of Pennzoil Synchromesh since every post I came across claim the two Syncromesh fluids are the same, just priced differently.
Once I got home, I found out that GM Syncromesh + FM is NOT the same fluid as Pennzoil Synchromesh (more viscous/thicker). Maybe everyone's referring to the non-FM variant which is cheaper. Just an FYI for everyone, there are two types of GM Syncromesh fluids.
Let's cut to the chase... shifts feel just as good as when I put the RP Synchromax in, however the 3rd gear grind is almost non-existent. Let's see how this stuff fairs in the next few hundred miles. It seems like Royal Purple simply might not be Aisin-friendly. However, in the BMW community we love RP fluids, or should I say the ZF gearboxes do.
Old Dec 17, 2008 | 10:59 PM
05rex8's Avatar
sold the 8... :(
You are correct, RP is not good for our trannies. Their motor oil is fine, however.
Old Dec 18, 2008 | 12:28 AM
TrochoidMagic's Avatar
is adjusting valve lash
[QUOTE=CaliAgents1688;2774555]I've had some very slight grinding issues going into 3rd as it doesn't happen all the time and the grind only occurs for a fraction of a second.
can you be more extensive with the details?
which fluid seems thicker? which actually is?
and for the GM synchromesh, does it state the viscosity?
can you also give some info on the different one stating synchromesh+FM?
i currently picked up the pennzoil synchromesh, and that should be the same fill as the one GM uses. unless they ALSO have a different formulation... the synchromesh+FM??? in which i would like to know if it has a different (thicker) viscosity...
thanks, and keep us posted on your impressions of the fluids.
oh, which one are you on?
Old Dec 18, 2008 | 01:10 AM
[QUOTE=TrochoidMagic;2774779]
Pennzoil by quite a margin.
Neither of them state the viscosity on the bottles. I'm sure the information can be found online on the respective spec sheets.
GM Syncromesh + FM
GM Syncromesh "basic"
Sorry, should have been more clear with my post. The RX8 is using GM Syncromesh + FM. I have a beater CRX Si and that one is using a blend of GM Sycnromesh + FM and Pennzoil Syncromesh. They only had 4 quarts on hand and I usually use a quart to flush out the transmission of the old fluid. Hope this helps.
Old Dec 19, 2008 | 04:26 PM
^^thank you.
well hopefully soon i will try out the pennzoil's synchromesh, as i wanted to have a thicker fluid in there...
but let us know how things are with the GM+FM stuff as i may want to blend it in the future... or even go in to a GM dealer and talk to one of the technicians and see what weight rating their line of RWD vehicles are on.
hope for the best results on both...(crossing fingers)
Old Dec 19, 2008 | 05:23 PM
rotary.enthusiast's Avatar
The Local Idiot
I wouldn't recommend any of the fluids you've mentioned for use in our transmission. Synchromax/Synchromesh is a lot thinner than the OE fluid. It might shift a lot smoother now, but in the long run you could end up regretting it. I definitely wouldn't bang on it with that stuff in there.
Old Dec 21, 2008 | 06:17 PM
kersh4w's Avatar
Hit & Run Magnet
i love my redline mt90....
Old Dec 22, 2008 | 11:51 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
General consensus on here is to go with Redline or AMSOIL GL-4 fluids.
Old Dec 24, 2008 | 09:41 AM
mazdaverx7's Avatar
RX-Heaven
this is all good research info i'm going to keep following this and see how this pans out. my question to the above is why go with GL-4 instead of GL-5?
Old Dec 24, 2008 | 09:59 AM
alnielsen's Avatar
GL-5 is hard on the syncros.
Old Dec 24, 2008 | 12:36 PM
rotarygod's Avatar
Holy crap use the right product!!! RP Syncromax is the WRONG stuff!!!!!!! Do not use that in an RX-8 transmission! No wonder you had grinding issues. RP Max Gear 75W90 is what you want to use in the transmission and rear end.
If the people who say RP is not good for RX-8 transmissions have been basing their opinion on the use of Syncromax, no wonder you feel that way! You may as well use canola oil. Syncromax is good for Hondas and other transmissions that can use a motor oil type of lube that is much thinner. It is not to be used in transmissions like the RX-8's.
While there are other good products out there, I'll put RP Max Gear against any of them anyday and it will quite easily hold it's own and then some.
Old Dec 24, 2008 | 12:41 PM
RG is back!!!
Merry Christmas man
Old Dec 25, 2008 | 01:34 AM
wow,
so glad you are back fred. ran rp maxgear for 50k miles.. no problems.. go figure..
Old Dec 25, 2008 | 03:53 PM
ASH8's Avatar
Super Moderator
Tha MAN is in the House!..
Welcome Back Fred, sorry Rotary God!!!!, now where have you been?
We, well most of us missed you.
Old Dec 25, 2008 | 04:05 PM
ASH8's Avatar
Super Moderator
BTW...RX-8
GL-4 For Manual Transmission.
GL-5 For rear Diff.
Both are 75W90
Old Dec 25, 2008 | 04:38 PM
mazdaverx7's Avatar
RX-Heaven
^^ very good info to know. being new to these cars requires the right information when researching.
Old Dec 29, 2008 | 05:30 PM
Too lazy to search. How much of the RP maxhear 75W90 do you need for the tranny and rear end?
Old Dec 29, 2008 | 09:10 PM
4 qts.
Old Dec 30, 2008 | 06:46 AM
DOMINION's Avatar
I don't buy Kool-Aid
Good info to know. Now whos going to do mine for me
Old Dec 30, 2008 | 06:53 AM
mysql's Avatar
Doppelgänger
/me waits for the sudden influx of people needing new transmissions after reading the advice on this thread.
Old Dec 30, 2008 | 08:57 AM
mazdaverx7's Avatar
RX-Heaven
what do you guys think of motul trans fluid?
Old Dec 30, 2008 | 10:59 AM
[ waits for mysqls advice ]
Old Jan 12, 2009 | 11:14 PM
risky business's Avatar
IRC Founder
i just put synchromesh + FM in my tranny and it shifts like butter... its amazing stuff
Old May 27, 2009 | 11:37 AM
Hi Flying 8's Avatar
Expand-give us your thoughts because many things have been suggested in this thread.
Old May 27, 2009 | 11:48 AM
rotarygod's Avatar
The first thing is DO NOT USE SYNCROMAX!!!! It's the WRONG product from RP!!!
