High Power vs. Low Power Model
Old Jan 7, 2003 | 08:14 AM
Styjan's Avatar
Rotary Freak
I wonder what makes one engine higher power then the other and how much it would take to make the low power engine to the high power spec?
Electronics, Intake, ......??? It's the same engine right?
Old Jan 7, 2003 | 08:19 AM
R.Cade's Avatar
I would guess same engine, diffrent ECU tuning, one is rev limited due to the auto-trans, so it doesn't make the peak power of 250 horses at 8500, it just can't rev that high.
Both the auto and manual should make near identical power at 6500 rpm for example, but the manual can rev beyond that for a higher HP number, though it doesn't actually put out any more torque. HP = Toque x Revs
Sputnik's Avatar
As we understand it, the only major change is the rev limiter.
---jps
Old Jan 7, 2003 | 08:21 AM
Styjan's Avatar
Rotary Freak
So it will cost more money to take the rev limiter off?
Old Jan 7, 2003 | 08:27 AM
better question styjan- how much is a new torque convetre or auto tranny when they blow up from going to 9000 rpm?
Old Jan 7, 2003 | 08:33 AM
Styjan's Avatar
Rotary Freak
Is the low power auto only?
Old Jan 7, 2003 | 08:35 AM
yeah in north america. japan definetly and i think europe get the option of the 4 speed auto or a 5 speed manual. but here it is 4 speed only.
edit: this is straight from mazda search mine or hercs post from the last 3 days for hercs link to three press releases. the third one is a 12 page pdf and on the last page is a chart show this and other stats.
Old Jan 7, 2003 | 08:37 AM
Sputnik's Avatar
As far as we've been told so far.
---jps
Old Jan 7, 2003 | 09:06 AM
Styjan's Avatar
Rotary Freak
No worries then.
Old Jan 7, 2003 | 07:20 PM
eccles's Avatar
Prodigal Wankler
I don't believe so. The low-power motor produces more peak torque, and makes it at lower revs. My guess is that they've given it a slightly longer intake tract, or possibly even different port size and shape.
Old Jan 7, 2003 | 07:29 PM
Buger's Avatar
RE member
There was a good discussion at the below thread:
http://www.rx8forum.com/showthread.php?s=&threadid=1370
An excerpt: "The auto version has less horsepower because it can't rev as high as the 6-speed version. If anything, it has been "tuned" to have more torque at lower rpms rather than detuned. The 6-speed version has 3 different length intake paths and (if memory serves me correctly) the auto version only has 2 (missing the high rpm path). I'm not sure if the actual ports on the auto trans renesis will be made differently (higher costs). I am pretty sure that a simple change in the intake manifold is the difference."
The 2 intake paths for the auto have been optimized for different ranges.
Brian
Old Jan 7, 2003 | 08:57 PM
Sputnik's Avatar
Originally posted by eccles
I don't believe so. The low-power motor produces more peak torque, and makes it at lower revs...
And what reliable source has given you that information?
---jps
Old Jan 7, 2003 | 11:24 PM
eccles's Avatar
Prodigal Wankler
Try this thread.
Old Jan 8, 2003 | 01:34 AM
B-Nez's Avatar
The Hi-power has 3 intake ports per rotor, whereas the Standard power has only 2 per.
This comes right out of the presskit, page 28-29. Cool diagram of the intake system, too.
I'm still reading it, so I will add any other details I come across.
Edit: The variable intake control system opens and closes the secondary (and auxiliary ports). The Hi-power also has what they call a variable fresh air duct.
Old Jan 8, 2003 | 08:49 AM
Sputnik's Avatar
Try this thread.
Take that with a big grain of salt, Hercules has a reputation of spreading around speculation as fact.
Notice that there weren't any HP/TQ numbers released with the press kit? It's because Mazda is still working on the numbers. I don't know what they're doing, or how close they are, but they did not have final numbers to release with the launch yesterday.
---jps
Old Jan 8, 2003 | 08:59 AM
ZoomZoomH's Avatar
Mulligan User
i was reading through the press kit, and indeed the intake runner between the high power and low power is different. the high power engine has these 2 extra 'auxilary ports' compared to the standard motor (think 5th & 6th ports on the NA 2nd gen RX-7 :D)
so yeah, it's not just a rev limiter, they also altered the intake manifold to gain top end POWA!
Old Jan 9, 2003 | 03:13 PM
B-Nez's Avatar
AND the side housings. Don't forget that the side housings will also be different with the extra port each.
Old Jan 9, 2003 | 05:05 PM
Rx4FUN's Avatar
Sputnik-
The HP and TQ numbers are mentioned twice in the press kit. Japan/North America high power version gets 247hp/159lb-ft of torque. You can see a chart on page 21 and a graph on page 23 that both indicate these values. I'm guessing that these numbers are pretty set.
The engine differences between the High and Low power versions that I could find in the press kit are:
Variable Fresh Air Intake (Opens above 7500RPM)
3 Path intake Manifold (Primary, Secondary and Auxiliary)
Auxiliary Airflow valve
3 intake ports per rotor (vs. 2 for the Low)
ECU programming to control the above equipment
(The press kit just says the Renesis has 3 injectors per rotor, but based on the photos I think the High power version has 3 fuel injectors per rotor, but the Low power only has 2. One per intake port. )
~Robert
Old Jan 10, 2003 | 08:02 AM
Sputnik's Avatar
Originally posted by Rx4FUN
...The HP and TQ numbers are mentioned twice in the press kit. Japan/North America high power version gets 247hp/159lb-ft of torque. You can see a chart on page 21 and a graph on page 23 that both indicate these values. I'm guessing that these numbers are pretty set...
I was told by good authority that they weren't set in stone yet, and even the press kit and websites still say "Provisional" next to them.
---jps
Old Jan 10, 2003 | 01:39 PM
Rx4FUN's Avatar
Do you think that this late in the game (production is supposedly going to start in February.) that they would actual increase the HP? I would think that they are probably in the final stages of long term testing and the provisional statement is just in case they run into something that requires them to lower the values.
Don't get me wrong. I'll take every bit of power they give me! :D
~Robert
Old Jan 10, 2003 | 04:59 PM
Sputnik's Avatar
I don't know when, what or why, if the change will be a little or alot, or if it will be more or less, but I have it on good authority that the numbers aren't set in stone yet.
---jps
uZu
Dec 30, 2015 12:35 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
CA441914
Aug 5, 2015 11:33 AM
Stubbs
Jul 28, 2015 09:23 PM
Jvswan
28
Jul 23, 2015 09:02 AM
